biggest tires on stock rims
Old Jan 8, 2008 | 06:06 PM
Crayola_G's Avatar
Default biggest tires on stock rims
whats the largest tire width wize i can smack on the tC w/ stock rims....dont flame me f*kers......
Old Jan 8, 2008 | 08:04 PM
nodsetse's Avatar
I suppose that depends on what you mean by "can", and how safe you want to be.
It's technically dependent on the aspect ratio of the tire, not just the wheel width. For both safety and optimal performance, if you're using 45 series or lower, then the wheel should be at least 85% of the tire width. For aspect ratios of 50 or greater, the wheel only needs to be 70% of the tire width.
This means that the 215/45 on the tC's 17x7" wheel is perfect. That said, many people have used 225/45 on the stock wheel without issues, but I wouldn't recommend anything wider without going to a 50 series tire, which also isn't recommended. Now I'm sure you could find some place that would sell you a 235 or even a 245/40 and get them on the stock wheels, but it wouldn't be safe and the performance would suffer too.
Old Jan 9, 2008 | 05:46 AM
CRUZtc8's Avatar
245/40 is probably the largest tire you can go with stock wheels
Old Jan 10, 2008 | 07:23 PM
RogerTTR's Avatar
Our fitment team recommends 225/45R17's!
Old Jan 10, 2008 | 07:51 PM
DiscountTireDirect's Avatar
Upgrade your wheels to 17x8 and go for the 245.40.17. With the stocks go with a 225.45.17. If you put the 245.40.17's on your stocks they'll look like donuts. but if you must, against recommendation, anyway... at least look at the Falkens, they tend to run a little narrow.
Old Jan 16, 2008 | 01:16 AM
bigwillystyle23's Avatar
DONT DO THAT! haha im jk do whatever you want. its your car.
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
Squishface
Sep 15, 2015 06:51 AM
Scion0814
Feb 12, 2015 01:41 AM
pscionicpowers
22
May 18, 2006 01:40 PM
