at the gas pump... does YOURS click 99/100 times?
Old Jan 8, 2004 | 09:43 AM
hahajoey's Avatar
Default at the gas pump... does YOURS click 99/100 times?
everytime i get gas.. like u know.. with all cars..
u just click it. set it and let it do it's thing..
but with my xb. i've noticed.. no matter what
gas station i go to, where i go to, what kinda gas
or whatever amount it'll stay clicked(fueling) for a few
secs.. then i gotta manually hold it.. soemtimes
even like 1/2 way because if i pull it all the way
open.. it just clicks like its FULL when i barely put
1-2 galloons in my near empty tank.
i'm getting sick of this. but i just wanted to know
if other people are having this issue.. I TRIED
all the gas stations out there locall..
from those private ones.. to arco, chevron,
shell, 76... EVEN a texaco and a that other one
CITGO or whatever 7-11 always has..
its just annoying..
i've tried to like push the nozzle towards
the right, the left,, aim it more up.. more in/down..
like more OUTWARD.. like even turning the damn nozzle gun
upside down.. it doesn't work.. i always gotta stand there.
thank god our tanks our small..
PLEASE POST AND REPLY to this =)
Old Jan 8, 2004 | 10:28 AM
UrbanDrum's Avatar
I have the same Prob...Eric m. didn't beleive me...Turning the whole nozzle upside down has worked for me though. I just came back from pumping gas at costco and I had no prob and the price is good...I guess I might just keep going there...I wonder if that's cheap quality gas though :?
Old Jan 8, 2004 | 03:35 PM
smilygo's Avatar
Default Mine does it sometimes...
My xA does it sometimes. It helps if you remove the cap and wait for 3 minutes or so to release the pressure.
Old Jan 8, 2004 | 03:38 PM
DjFrOsT's Avatar
my box does the same thing...what i do is hold the pump at a certain angle...just so that there is a little crack to let air in and out...cause i guess its the press which is clickin the pump...soo if you let some pressure out...you should be aight...but i just hate holding the damn pump the entire time i'm there...
Old Jan 8, 2004 | 03:41 PM
EV_AIC-xB's Avatar
i have same problem, particular gas station pumps will do that...
i don't recall which gas station I did not have problems with...
Old Jan 8, 2004 | 03:43 PM
Munch's Avatar
WOW I hope they fix that problem before mine gets here.
Old Jan 8, 2004 | 04:24 PM
bBted's Avatar
mine does that too...but only once a while
Old Jan 8, 2004 | 04:29 PM
xBguy's Avatar
I have only used union76 (unocal) gas and have never experienced the trouble y'all are describing. The gas nozzle does not have any kind of rubber boot or sleeve that requires a seal to the fill tube, therefore the tank can "breath" and not build up pressure. Does this make any sense?
Old Jan 8, 2004 | 04:39 PM
debris's Avatar
mine does it all the dang time too...its so annoying.....
Old Jan 8, 2004 | 05:59 PM
obz's Avatar
obz
If you try shoving the top of the pump all the way in it'll sometimes fix it, or it may be too far in so pull it out a little bit and it'll fix it. I had the problem once and I pulled it out a bit and it was taken care of. It has to do with the angle of the inlet to the gas tank. What's happening is the gas is hitting against a lip inside and not draining down fast enough that makes the pump think it's full. Try it out. Worked for me!
Old Jan 8, 2004 | 06:18 PM
PandaIst's Avatar
Damn....i have that same problem :? ...only with certain gas stations. For me it only happens at privately owned independent stations though which i only went for gas cause i was very desperate. I mostly go to chevron, mobil, or arco which i don't have a problem pumping my gas at.
Old Jan 8, 2004 | 06:34 PM
hahajoey's Avatar
i have tried all angles, all positions..
its just tiresome trying so hard just to get
gas.. and i have tried to PULL back that
rubber splash thingy on the pumps that have it..i'll try that
leave a gap for air thing..
but waiting 3 mins to DEpressurize just to get gas
is absurd! thats gonna take forever! hahaha it might
just work. i tried getting gas a few times with the engine on
just to releave the pressure, that worked a LIL.
Old Jan 8, 2004 | 06:36 PM
Milhamscion's Avatar
I have fueled quite a few xa's and xb's and never had a problem. :?: Maybe Im just lucky?
Old Jan 9, 2004 | 12:14 AM
stellarhavoc's Avatar
I've only refueled once thus far.. but yah that happened!! i was like WTF? i filled up from E with only 4 gallons in the no friggin way!!
Old Jan 9, 2004 | 02:37 AM
tintsem's Avatar
Damn, I thought it was just me. I'm having the same problem. I was just filling up my truck and my wife was next to me filling up the XB and she could not keep the thing pumping. I told here that she's been driving for this long and still cant figure it out? So I proceeded to do it and it did the same damn thing to me.
Old Jan 9, 2004 | 02:42 AM
1NZFE's Avatar
Any Scion owners OUTSIDE California with this problem?
Old Jan 9, 2004 | 03:28 AM
hahajoey's Avatar
haha! lucky bastard.
Old Jan 9, 2004 | 04:02 AM
HotBox's Avatar
dude never had this problem til a few days ago ____ed me off cause i know it wasnt full but i didnt wanna keep on going was a little scared that the gas would come out
Old Jan 9, 2004 | 04:48 AM
JDMxB's Avatar
Default Re: at the gas pump... does YOURS click 99/100 times?
its just annoying..
https://www.scionlife.com/forums/viewtopic.php?t=4203
Do a search next time, Newbie.
Old Jan 10, 2004 | 03:43 PM
itimebomb's Avatar
Default toyota thing
its a weird toyota thing. i had a 92 camry once and it did the same thing every once in a blue moon. even the new cars here on the lot do it every once in a while.
