blowin foglight fuse with HID's
Old Feb 7, 2008 | 04:12 AM
SSVworks's Avatar
Default blowin foglight fuse with HID's
so stock fogs worked great with HID's until i flicked em on onetime with the headlights as i was starting the car. it blew the 15amp fuse.... which makes sense since the the HID's can draw as much as 20amps on start-up. anyone else have this issue?
Old Feb 7, 2008 | 05:10 AM
lvbitwiz's Avatar
not here, and I run my fogs all the time with the HIDs, then again, I'm also running the HID through a relay and not directly off the headlight harness
Old Feb 7, 2008 | 05:13 AM
SSVworks's Avatar
that makes sense. i just plugged into the factory harness. now that i upped the fuse, i should be fine. thanks.
Old Feb 7, 2008 | 11:54 PM
simplexb's Avatar
Yeah, I'm totally fine, I have 2 HID kits on my car. Headlights and foglights... still no problem!
Old Oct 14, 2008 | 03:31 PM
cobb's Avatar
Yeah, I had that problem with my xa.They worked the first few times, then bam, blows fuses. The manufacture I got them from recommended using a larger fuse, I bought a relay kit from another vendor.
Old Oct 15, 2008 | 10:28 PM
Ravisxb's Avatar
i have no problems at all low beam, high beam and fogs are 8000k hid. the only problem is that only one fog turns on sometimes but if i thurn ithe headlights on and off again then they both come back on
Old Oct 19, 2008 | 03:23 PM
Redbeard46's Avatar
OK, so I see maybe THIS is the thread for me to post this question.
I've got 8000k HID's, and want to make my Fogs HID's as well (Matching)
on the next gen xB's are the Fogs H3's or H11's?
Old Oct 20, 2008 | 12:58 AM
Ravisxb's Avatar
h11
Old Oct 20, 2008 | 10:11 PM
roXor_boXor's Avatar
Are you saying you put a higher amperage fuse in to prevent the fuse from blowing and you are using the stock harness with HID's in your fog lights??
You need a relay in there. It does not sound like you have one. There are many horror stories about melting down the stock wiring harness by trying to use it alone with HID's.
There are a few HID experts here that should chime in here if I read your post correctly.
Old Oct 21, 2008 | 03:40 AM
cobb's Avatar
I had an hid vendor tell meto do that as his hids take 15 amps each at start up, but they settled down as they brighten up. I went with another hid vendor and bought a relay cable.
Prolific998
Scion tC 1G ICE & Interior
Apr 16, 2017 06:09 PM
mischman
Sep 15, 2015 03:38 PM
kfisher8
Aug 14, 2015 03:21 PM
Jumphiggggg
Jul 15, 2015 02:29 AM
SoCal_CJ
Jul 14, 2015 09:14 PM
