Put on my K&N Filter this past week......
Old Mar 16, 2008 | 08:09 PM
jeems's Avatar
Default Put on my K&N Filter this past week......
and I've noticed decreased gas mileage and no increase in acceleration or actually any positive results.
Any idea why?
Old Mar 16, 2008 | 10:51 PM
agentorunge's Avatar
you've just been on the gas a bit harder probably to hear the sound. i got one in too and removed my snorkel. did it like 2 tanks ago and didn't necessarily see any gains in mpg yet.
Old Mar 16, 2008 | 11:13 PM
jeems's Avatar
nope cause i haven't heard a sound difference either!
Old Mar 16, 2008 | 11:22 PM
Sciond's Avatar
the difference it very small....
Old Mar 17, 2008 | 12:31 AM
i removed the snorkel and dropped in the k&n at the same time, so i guess thats why i noticed the sound difference.
Old Mar 17, 2008 | 05:09 AM
jeems's Avatar
what do you mean removed the snorkel. what is this snorkel you speak of?
Old Mar 17, 2008 | 05:27 AM
https://www.scionlife.com/forums/vie...norkel+removal
very long thread, but its pretty much that bottom pipe that leads into the stock airbox that you dropped the k&n into. its only screwed on by a bolt near you front headlight. then pull off the snorkle from the airbox, grab it by the skinny part, found it to be the easiest. you'll just have to figure that out. but it just pulls out, its very simple.
Old Mar 18, 2008 | 05:37 AM
bB2NER's Avatar
Music City Scions
Yeah, remove the snorkel so the airbox can breath better. Then pull the ECU fuse for 10 minutes and replace so the computer can relearn how to run with the new upgraded airbox. Then you will see the better mpgs.
Anytime you upgrade or change anything it's a good idea to reset the ECU.
Old Mar 24, 2008 | 11:54 PM
mrsocks's Avatar
i switch to K & N in everything i can and as soon as possible. performance is why.
they are not really cheaper (overall).
they let more dirt in (more air = more dirt).
they let more gas in (more air = more gas), more air/fuel = more power.
anyway, most of the performance mods seem negligible considering that they increase at a percentage and percentages of 100hp don't really add up for the bucks spent. it is FUN though and that is why i continue! thanks!
Old Mar 24, 2008 | 11:55 PM
mrsocks's Avatar
hey bBtuner.....would the ECU reset if the battery were unhooked for a similar period of time?
Old Mar 25, 2008 | 12:05 AM
jeems's Avatar
where IS the ECU fuse anyway?
Old Mar 25, 2008 | 03:53 AM
bB2NER's Avatar
Music City Scions
I think you can but then your clock and radio stations will need to be reset.
The fuse is in the box under the hood drivers side.
Old Mar 25, 2008 | 04:09 AM
refer to this thread. its in the tech section.
https://www.scionlife.com/forums/viewtopic.php?t=33062
Old Mar 25, 2008 | 04:51 AM
mrsocks's Avatar
thanks bB....just wonderin' 'cause last dealer trip (at 30k) i KNOW they had the battery unhooked and since then the thing has run the best that it has since brand new. again...thanks for the info!
Old Mar 25, 2008 | 06:22 AM
bB2NER's Avatar
Music City Scions
NP, the fuse should be clearly marked in the fuse section of the owners manual.
awdmofo
Feb 8, 2016 05:58 AM
hampton1100
May 28, 2015 07:32 AM
evolving_machine
Jan 13, 2015 08:04 PM
cid_mcdp
Jan 5, 2015 02:45 PM
Godfryness
Jan 2, 2015 11:18 PM
