Shifter Cable Bushings (Dr Isotope)
Old Apr 7, 2008 | 04:20 AM
x_Batman_x's Avatar
Default Shifter Cable Bushings (Dr Isotope)
So I know some people (including myself) were confused about how to install Doc I's cable bushings as he sends four while other companies include only two. I decided just to have at it and see if I could figure it out, and it turned out to be quite simple so I threw together a little DIY :-)
So start out by taking out the upper intake box and upper pipe. I decided that as long as I was going to take some of my stock intake out, I might as well take out the whole thing and throw on the CAI that has been sitting in my room since X-mas:
Alright now locate the two shifter end links, they are close to eachother and the most visible one is below the brake fluid tank:
The other one is kind of hidden behind a part of the transmission assembly so just look around where the arrows are pointing:
Okay now pull the lock pin out of the first one and put it somewhere safe because you'll be reusing it:
lift the endlink off the stud and push the stock rubber bushing out, and make sure not to drop the washer:
you should have this:
now go ahead and repeat the process for the other one:
grab your new delrin bushings :-)
mmm
Okay so I'll show you now how you are to assemble the bushings in the holes of each end link. What you do is sandwich them together with the ring of the endlink holding the narrow parts of both bushings. Heres how you are going to stack them:
okay so go to the first stud and place one of the bushings on it with the narrow side up:
then place the end link on top:
now the other bushing:
and secure it with the lock pin
repeat the process on the other link (sorry don't have as many pictures for the second link, but it shouldn't be hard to figure out):
Anyways get in your car and make sure you can get into every gear
put your intake back together (or in mycase install the CAI) and test out your new cable bushings :-)
Okay so I hope this helps anyone who is confused out. These bushings go great with the Doc's gearswitcher. The shifter moves into gears more smoothly and affirmatively. There is also less slop, they definatly complete the gearswitcher package.
Old Apr 7, 2008 | 06:05 AM
WAlterEgo's Avatar
nice write-up, thanks. too bad the pictures are dark n some are blurry. i'll be needing this in the near future.
Old Apr 7, 2008 | 09:21 PM
x_Batman_x's Avatar
yeah I should have looked for a better camera
Oh well lol
Old Apr 7, 2008 | 09:42 PM
Bmcclure's Avatar
i cant the maf sensor back on the stock airbox! the holes wont line up!
Old Apr 7, 2008 | 09:45 PM
Ace83's Avatar
Ronin Scion
there's a write up on this i believe but good FYI.. to add, dropping the pins in the engine is a no no
Old Apr 7, 2008 | 10:04 PM
Bmcclure's Avatar
nevermind i got it..im an idiot lol
Old Apr 7, 2008 | 10:06 PM
x_Batman_x's Avatar
Oh yeah for sure, be real careful guys if you dont push them in steadily they might spring out of your grip.
Oh and Bmcclure, are you having trouble plugging the MAF back in or sticking the pvc valve thing into the bracket?
Old Apr 7, 2008 | 10:07 PM
Ace83's Avatar
Ronin Scion
especially when your are using some grease on the bushings they are slippery
Old Apr 7, 2008 | 10:08 PM
x_Batman_x's Avatar
oh okay nvm then lol. Good job
Old Apr 9, 2008 | 10:38 PM
yellowxhoodie's Avatar
wow good write. def gonna need this next week.
but 1 questions, whats the advantage to changing the bushing...?
just smoother shifts....?
Old Apr 9, 2008 | 10:43 PM
Ace83's Avatar
Ronin Scion
crisper shifts.. and easier engagements
Old Apr 9, 2008 | 11:32 PM
x_Batman_x's Avatar
yeah, its a bit smoother but moreover the real difference is that as Ace said its crisper. Its hard to accuratly explain, I suppose "more precise" sums it up pretty well.
Old Apr 10, 2008 | 02:55 AM
amp0804's Avatar
I actually had a hard time getting these on. They were just a LITTLE too big so I had to sand one down to get the pin in. Overall I feel the difference. Very impressive.
Old Apr 10, 2008 | 03:56 AM
hawgs74's Avatar
worthwhile mod?
Old Apr 10, 2008 | 04:53 AM
x_Batman_x's Avatar
Originally Posted by hawgs74
worthwhile mod?
absolutly.
(if you have a short shifer, I dunno how it would feel on the stock one...)
Old Apr 10, 2008 | 05:53 AM
danyo's Avatar
yeah the shifts are definitely a bit more precise. Just installed my NST cable bushings two days ago and a skunk2 weighted shift **** at 440 grams. It makes my TWM stage II shortshifter more precise and easier to shift! A lot more fun to drive now.
Old May 25, 2008 | 04:59 PM
cluelessTC's Avatar
so dont reuse the metal washer?
Old May 26, 2008 | 06:53 AM
x_Batman_x's Avatar
thats right, do not reuse the metal washer. I actually tried to cram one on to the one of the links because it felt loose with just Doc Is bushings and I almost lost the loc pin for doing so.
Old Jul 16, 2008 | 02:51 AM
huslindan's Avatar
i have the twm ones i am gunna put them on tomorrow but the thing is one peice is it the same you think ?
Old Jul 16, 2008 | 03:43 AM
x_Batman_x's Avatar
yeah its the same. the only difference is you slide a single bushing into the retaining ring rather than sandwiching two pieces in.
