Coil Pack Female Plug?
Old Apr 8, 2008 | 02:48 PM
aggj24's Avatar
Default Coil Pack Female Plug?
Anybody know where I can get a coil pack plug without having to buy a whole new wiring harness?
Not the coil pack but the female plug that connects to the coil pack?
The clip on it broke and I think it gets loose with vibration.
_____
Old Apr 8, 2008 | 04:52 PM
Sasnuke's Avatar
Did you check with your local dealer? They may be able to order just the plastic connector.
Old Apr 8, 2008 | 05:00 PM
aggj24's Avatar
they just said that i would have to order a new harness...ill call another toyota and see if they say the same thing
Old Apr 8, 2008 | 05:01 PM
vettereddie's Avatar
How would you replace it? The connector pins aren't removeable so you'd have to cut the wiring and re-splice. If you're worried about vibration and want a permanent fix, you could epoxy the connector on. Only downside is it would probably get damaged if you ever needed to replace the coil pack.
I doubt the dealer would carry the connector only, maybe you could hunt around at the junkyards to find one. Does the Echo use the same connector?
Old Apr 8, 2008 | 05:11 PM
Sasnuke's Avatar
The wires are removable from the connector, thats why its possible it may be sold seperately. But actually a junk yard is a good suggestion. Echo, Yaris, xA, xB, & Prius all use the same coil packs, hence the plug will be the same.
Old Apr 8, 2008 | 06:06 PM
Oh, didn't realize they were. I'll have to check them more carefully I guess. Do you have a P/N for the plug?
Old Apr 8, 2008 | 06:58 PM
aggj24's Avatar
well i found out a price for a new wiring harness...an oustanding $905.90..to bad im not buying it... i dont even know where a junk yard is in my area...lol but that is my plan...to cut the connector off the old one and solder/ heat wrap it back together..or maybe i should just take the whole wiring harness. does anybody know if there any after market coil packs and wires that would be niceto have
Old Apr 8, 2008 | 10:57 PM
jct's Avatar
jct
new aftermarket coil packs cost around 700 dollars for a set of 4 i forget who sells 'em they posted it on sl a few months ago
Old Apr 9, 2008 | 04:20 AM
LuNcHbOx13's Avatar
hey aggj24 pm sent, good luck
Old Apr 9, 2008 | 01:21 PM
Wow, I bought a whole motor and transmission for $500. It came with coil packs, starter, alternator, even all the sensors still installed. Didn't get the wiring harness though or I would have offered that up. Do you need new ones?
Old Apr 9, 2008 | 03:41 PM
aggj24's Avatar
i would sure like a new wiring harness
Old Apr 9, 2008 | 03:43 PM
aggj24's Avatar
i dont see a pm
Old Apr 9, 2008 | 05:51 PM
lastlookcustoms's Avatar
The toyota part number for the connector you need is:
90980-11885 msrp - $6.03
That doesnt come with the terminals, if you need those, the part number is:
82998-12340 - MSRP - $5.46 Each
and those come with 160mm of wire attached to them so you can splice back into your harness. That is also each.
Old Apr 10, 2008 | 03:10 PM
aggj24's Avatar
your saying toyota sells em like that..them bastards said i cant...thanks for the info
Old Apr 10, 2008 | 03:13 PM
Of course toyota sells them. The problem is that most parts guys now are so damn lazy they dont want to take the five minutes to help out a customer and get the wiring book from service, look up the connector and handle it. Luckily, I have my own books...
Old Apr 10, 2008 | 05:19 PM
aggj24's Avatar
maybe i needa get my hand on one of those books...anyways so i ordered that part should be getting it tomorrow or by monday..i hope this fixes my car..my CEL keeps trippin and i already have a new short block new intake valves and exhaust valves for cylinder one a brand new vvti and new coil packs new spark plugs piston and rod all because of water through the inake..ive been having a cylinder 1 misfire before i got the car back from the dealership..and after i got it back it was gone for bout a week then the CEL turned on again..i checked it and its still a cylinder 1 misfire( code P0301) does anybody know whats going on besides my wiring harness plugs clip is broken?
Old Apr 10, 2008 | 08:30 PM
PM sent, was wondering why the short block was replaced.
yupinmytC
22
Jul 27, 2024 07:08 PM
ruzzzell
Oct 11, 2015 04:18 PM
Luna7ic
Sep 28, 2015 03:30 PM
ScionDP
Sep 8, 2015 02:17 AM
Topfueltom69
Sep 6, 2015 05:25 PM
