Engine Swap...
Old Dec 6, 2004 | 02:18 AM
smurf3642's Avatar
Default Engine Swap...
What engines out there would fit in the tC's engine bay??
Supra?? -more concerned with right now...
Old Dec 6, 2004 | 03:21 AM
ScummyMcOwnage's Avatar
unless you plan on making the tC RWD, you're not getting a supra engine in there....there is a topic on this, I'll search for it.
Old Dec 6, 2004 | 03:24 AM
BSP_5c10n's Avatar
Wow the car JUST came out and already we're talking engine swaps.
Old Dec 6, 2004 | 03:28 AM
JSVH's Avatar
I think the V6 from the Camry would be your best bet. Forced induction is probably a better option though.
Old Dec 6, 2004 | 03:36 AM
https://www.scionlife.com/forums/vie...ht=engine+swap
Old Dec 6, 2004 | 03:56 AM
lriicelboy's Avatar
i wouldn't mind a RWD tC.... =) drift!
Old Dec 6, 2004 | 04:25 AM
spider's Avatar
thats what i'm sayin'. why would you want to swap the motor out? the current motor has plenty of potential. a lot of aftermarket parts, as well as forced induction kits are coming out (greddy and turbonetics are working on turbo kits).
Old Dec 6, 2004 | 04:28 AM
If they don't make this, I plan on keeping my car and fabricating a RWD tC as a project waayyy down the road, just for the hell of it.
Old Dec 6, 2004 | 10:12 AM
hahaitzskippy's Avatar
good idea, the V6 engine is HIGHLY TQ'y and is REALL fast if you put SC on it. but question is, willl it fit??? i dunt think so,
Old Dec 6, 2004 | 04:41 PM
smurf3642's Avatar
that's the MAIN question I am asking...
is there room to add bigger engines??
Old Dec 6, 2004 | 06:02 PM
spider's Avatar
anything is possible with enough money.
Old Dec 6, 2004 | 08:02 PM
JSVH's Avatar
There is enough room in the engine bay if you are willing to work with it. It’s just a matter of figuring out what will fit and how much fabrication is involved. I would not be that surprised if you could drop the Camry V6 right in with little effort. Since we have the 4cyl Camry engine the mounts are probably the same. Of course with any engine swap you’re in for a big project. You have to worry about bunches of related components being compatible: Transmission, ECU, exhaust, fuel system...
Old Feb 10, 2006 | 09:13 PM
Serialk1llr's Avatar
OhioScions
**Resurrects a dead thread**
For the sake of kicking around weird ideas, what about a celica 3S-GTE swap, or a 1MZ-FE v6 (Out of the Lexus/Solara, and others)? Been reading a lot on the MR2 forums recently. Yeah, I know the 3S-GTE is a smaller engine, but is it more sturdy? I know so little squat about the camery v6.
I figure, hey, if they can jam a v6 in a MR2, why not us?
Old Feb 10, 2006 | 09:24 PM
ScionBandit's Avatar
DelMarVa
Scion Tuners
ur on the same page i am
Old Feb 10, 2006 | 09:29 PM
TheQuietThings's Avatar
have you ever actually looked at the engine bay in the tC? its tiny to begin with.
Also, if we are going to drop a bigger engine in the FRONT, the weight of the car is going to be distrubuted even worse than it already is.
BTW, moving to NA
Old Feb 10, 2006 | 11:27 PM
HKSpeed's Avatar
Toyota had to redesign the intake manifold from the Camry's 2azfe because of limited clearance between the engine and the firewall. So I suppose a 3sgte swap would run into clearance issues with the tC's firewall as well (unless you fabricate a custom intake manifold). I dont think you could fit the V6 into the tC, but people have put Camry V6's in 2nd gen MR2's.
3SGTE. yum....
Old Feb 10, 2006 | 11:42 PM
LBTc06's Avatar
I've been tossing the idea of putting a 1MZ-FE or even the 2MZ-FE into the tC. I know of a shop that'll do it. And with enough money, anything is possible. ;)
Old Feb 10, 2006 | 11:50 PM
hPower's Avatar
The 3SGTE would be pretty nice! And a supercharged 1MZ would be pretty cool as well. But at this point, its all speculation. I dont think anyone really knows for sure simply because no one has tried a swap yet... at least as far as I have seen or heard.
Old Feb 11, 2006 | 01:35 AM
OhioScions
I'll be the first to say I know squat about the 'possabilities', i just figured if they were cramming in a v6 into a mr2, anything was possible?
I think I was reading that they were running 18-20 lbs of boost on the 3SGTE, and i'll just assume a built block of course. As far as manafold clerance with the firewall, and again keep in ming i don't know a lot, is that a part of the design that could be relocated elsewhere (even if we have a tiny engine bay)
IF it turns out our 2az-fe's are just not up to snuff down the road to really take a beating, i'm under the impression other toyota engines -may- be up for it. So, someone go get us another engine and see if it has problems mounting. Hey, wait, i'll voulenteer my ride for that! *insert sponsorship here*
Old Feb 11, 2006 | 02:02 AM
TcPrincess's Avatar
well unless you want to do a lot of work to do a 2J rwd i'd say forget it. a 3S would be cool but you'll probably have a lot of custon work (mounts, axles,...). if it were me i'd just turbo the stock motor. a rwd tc would be cool but thats A LOT of work.
