Throttle Body
What size is the oem throttle body? Has anyone found any aftermarket ones that are available ex. bbk,holley,edelbrock,and str? I have been searching the only one I have found so far was an oversized 60mm tb. I want either a 62mm or 65mm. I had a civic with a 1.5Lnonvtec motor with i/e/h and I put a 62mm it screamed afterwords. Any one have any ideas what a good size to go would be for n/a setup? I leaning towards either the 62 or 65mm(more so to 65mm).
Originally Posted by ikonXone
why not take it to a performance shop and have it bored out with a new valve added? should be in the 250-350 range in price
Originally Posted by smurf3642
does increasing TB size reduce gas mileage??
Do you have to redo anything on the ECU??
or, does it just allow for more airflow??
Originally Posted by hahaitzskippy
bore? TB?
built TB?
dunno what does mean
built TB?
the tc only has a 55mm throttle body?!
my 2.0 ivtec comes with a 62.5 mm throttle body stock
This means that with more air flow....ALOT of power can be had (esp since it's a 2.4) for just a bolt on. 65mm would definitely be ideal for a 2.4 n/a motor.
Sciontcperformance.com has a 60mm throttle body for just $295 with core exchange.
Scion tC Performance - Throttle Body
Dyno, what is that? That is the problem with a lot of people, esp at the begining of a new car. Everyone wants to make a quick buck and turns out the products with no claims to the gains! I wish they would start backing up there products with a tested dyno sheet and comments from people who have bought the product and also had it dyno'd. How hard can it be to slap on a part and take a couple second run on the dyno? Not very.
It's not that they haven't provided us a dyno, it is just that they didn't show us seperate gains per item they added to the car. Combined is nice for a goal approach, but are we going to drop another $260 with core exchange on a TB if it only up'd the HP/TQ a 3points? Not likely.
I'm not affiliated with Scion tC Performance. I am just a fellow Scion Lifer who was giving the man some info based on a question he asked.
After reviewing the dyno sheets they provided I thought that the gains were reletively modest (23 WHP/ 20 TQ) considering they replaced the intake, TB and full exhaust. I was expecting to see somewhat more of a gain but that's just me. I agree with apexjr that they need to show dynos of before and after the TB.
But based on what they give
Without TB
With TB
Difference = 1.42 HP/0.96 TQ = not worth $295!!!
Without TB
With TB
tb is too small. Someone needs to actually make a 65mm for it. I had the 62mm on a 1.5 non vtec in the civic. My friend has a type r and has 67mm on his. The type r (integra) has a 1.8 engine in it. Stock tb size for it is 62.5. So being a 2.4L which is pretty big for a 4-cylinder I belive just changing the tb would help it breath a lot better. When a company actually makes a 65mm I will buy it and dyno. I am pretty certain there would be a significant gain with just a tb. Does anyone know what size the celica gts tb is? whould it bolt to tc? does it have electronic throttle?
