brake pedal problem?
Old Feb 21, 2009 | 09:28 PM
ilikepotatoes's Avatar
Default brake pedal problem?
about a month ago i got my rotors resurfaced and new pads. ever since then my brake pedal has been a little wobbly. not a tremendous wobble but when you hold it and push it side to side it moves about a good quarter inch back and forth. and when i push the pedal in sometimes it makes a clicking noise. any suggestions on what to do? i checked the bolt and looks fine should i bring it in to the dealer and have them check it out?
Old Feb 21, 2009 | 10:06 PM
CSUnited14's Avatar
u sure its not the clutch? my clutch makes a clicking noise...
Old Feb 21, 2009 | 10:38 PM
yea its def not the clutch man, def the brake. i think its making the clicking noise because its a litle loose. do you or anyone elses brake pedal move a little bit or is it really sturdy. my clutch and gas pedal do not move like my brake pedal does...
Old Feb 21, 2009 | 11:05 PM
CSUnited14's Avatar
last time i checked my brake pedal was solid... doesnt move side to side
Old Feb 21, 2009 | 11:18 PM
1SL0WTC's Avatar
mmmm my break pedal moves side to side little also... but i noticed this since i bought the car :X so its been 20k miles.. i should check if its tight. how do i do this? put my head to where the break pedal is and look to see if its loose?
Old Feb 21, 2009 | 11:25 PM
CSOCSO's Avatar
yeah.. my brakes click once when i press the pedal.... but it happened because i was stupid... tried to clean the caliper and i used wd40 to clean it... OMG.. dont do it.
since then my brakes clicks... you need to regrease them..
Old Feb 22, 2009 | 12:46 AM
CSUnited14's Avatar
lol what happens when u use wd40?? makes them very slick???
Old Feb 22, 2009 | 05:07 AM
squir3lz's Avatar
mine are solid
Old Feb 22, 2009 | 06:38 AM
CSOCSO's Avatar
do not use wd40 on your brakes. it will wash all the greasing out.. thats why is making the click noise every time u press the pedal. its not clicking constantly.. its 1 click every time u push the pedal and the brake pads engaging.
Old Feb 23, 2009 | 01:59 AM
xsupermario's Avatar
Makes lots of spin and car go boom. PRO tip! keep it.
Old Feb 23, 2009 | 02:20 AM
dodaddy's Avatar
hey your clutch makes that clicking sound too? do you have an OEM clutch?
Old Feb 23, 2009 | 06:12 PM
SW_08's Avatar
i think im gonna go check out my brake pedal when i get outta work....i dont recall it making a noise....
Old Feb 23, 2009 | 06:21 PM
mystik's Avatar
CinSity Scions
my brake pedal doesnt make clicking noises, but it does have a little bit of play left and right...maybe about quarter inch. im guessing its just like that, i also noticed it when i bought the car.
wonderworm
Nov 19, 2023 01:44 AM
Inazuma
20
May 3, 2023 01:58 AM
TotalChaos
Apr 7, 2015 09:02 PM
08bakerXxtc
Mar 19, 2015 09:51 AM
toyotaisme
Jan 10, 2015 10:24 PM
