Stalling issues at a stop...
Old Mar 24, 2009 | 03:30 PM
TheMerovingian's Avatar
Default Stalling issues at a stop...
So I installed my kit over the weekend. Runs pretty good except for after boosting, when coming to a stop (like at a light), the car's RPMs go really low and sometimes stalls (but this is only when stopped whether in neutral or in 1st gear). I read up on adjusting my Greddy Type S bov and tried various adjustments for the spring throughout the night last night but the issue is still there. I'm pretty sure it's the bov b/c the stalling issue would get worse after some adjustment, like if I revved up to 3000 RPMs, it would stall after. I was thinking about capping off the lower nipple to see if that solves the problem b/c right now it's venting to the atmosphere. What would be good to cap that off? I don't want to put on a rubber cap and have it melt off lol
Old Mar 24, 2009 | 04:12 PM
coryjames's Avatar
it will do this you just meetered a bunch of air then never let it hit the combo chamber so it dumps gas causing a rich condition and bad idle either recirc it or deal pretty much
Old Mar 24, 2009 | 04:16 PM
dave2610's Avatar
i had same issue. ptuning fixed it. you just need a good tune
Old Mar 24, 2009 | 04:25 PM
Carlanga's Avatar
Dave, did they lean it out? If they did how much and at what rpms/vacuum pressure on the map?
Old Mar 24, 2009 | 05:56 PM
dave2610's Avatar
to tell you the truth i have no clue what they did. you could pm their tuner on here. his sn is ptuning_tuner
Old Mar 24, 2009 | 06:02 PM
CarbonXe's Avatar
Mine used to get rich and dip down real low. If I tried to go from 3000+ rpm to idle, it would stall sometimes. The BOV needs to be tightened and you're going to need tuning. If you're going to PTuning for your tune, Toan should adjust the BOV.
Old Mar 24, 2009 | 06:07 PM
Ok good to know. I would've gone crazy trying to adjust the bov trying to get it right! lol I got a rubber cap at an auto parts store during lunch but the issue is still there. I'm hopefully getting an AEM F/IC next week, so I will be able to tune after. Until then, I will deal with it. I'm glad it's not compressor surge from the bov that is making me stall.
Something else though, I didn't see a dip in the road and may have bottomed out. A few minutes later I noticed my afr was reading a steady 14.7. Crap. I may have messed up my wideband sensor. I will get a better look at it after work when I get home. I hope I didn't mess that sensor up, cause it's $80 for another one.
Old Mar 24, 2009 | 06:11 PM
CarbonXe's Avatar
It's just that the MAF isn't used to seeing the dump to atmosphere. I got used to it and would just lightly blip the throttle when I was slowing down. Now that Toan adjusted it and tuned it, I can go straight to neutral from any RPM and it will find idle right away lol.
Old Mar 24, 2009 | 06:30 PM
gingles's Avatar
what i did to fix the stalling issue was put my MAF in between my BOV and throttle body...no more stalling for me
Old Mar 24, 2009 | 09:56 PM
aen's Avatar
aen
instead of letting it vent to atmosphere, let it recirculate, the air lost will be added to the air in the next run and balance itself out like that
Old Mar 24, 2009 | 10:03 PM
gingles's Avatar
aen even when id id recirc my bov i found i would still stall...now i have the blow thru maf and let my bov vent to atmosphere
Mkn
Mar 26, 2015 01:47 PM
Nicole412
Mar 23, 2015 06:26 PM
TheTripleC
Jan 4, 2015 06:46 PM
toybox1
11
Apr 23, 2004 04:57 AM
toybox1
Feb 26, 2004 03:26 AM
