Stalling Problem - Revisited - Again!
ok .... my stalling problem has come back .... took to a new dealer (since stevens creek sucks .... don't get me started
) and they couldn't find anything except that the brake fluid was low (and it had just been in for service at stevens creek ... i said don't get me started). it seems that the clutch and brake pull from the same reservoir so it conceivably could not have enough to disengage the clutch while breaking on a hill. however it has happened on flat ground, albeit not nearly as often as going downhill. also, it doesn't explain why it happens most often at altitude and in the cold; if it was a fluid issue you would think it would happen more at sea level since fluid is compressed more at sea level than at altitude. also, when it dies it doesn't shudder like the engine is being dragged .... it just quits
so ... i know someone had a similar issue so any updates??? also ... who was the corporate person that was involved with the issue (all i have is the name aaron ... the dealer has no clue)????
Originally Posted by sithscripter
Just talked to a friend who had a similar stalling problem with his Celica GTS -- he said his problem was in the throttle position sensor.
andergtr
Jan 23, 2004 12:43 AM
andergtr
27
Jan 8, 2004 05:55 AM
