Squeeking Clutch Noise.... Plz Help
Old Jan 13, 2005 | 02:23 AM
Chrno's Avatar
Default Squeeking Clutch Noise.... Plz Help
hello.... Today i was driving my XB and everytime you press the clutch down to start the car or to shift gears, It'll make a Squeeking noise... the clutch doesnt slip. it still grabs.... does anyknow know what is the cause of the sequeeking noise? is it becuase the cable line is bad? or air bubbles in the clutch lines? (ours is hydrolic clutch i believe) Please if anyknow knows please respond ... Thank You, I Appriciate it a lot!
-Mark
Old Jan 13, 2005 | 07:04 AM
sciontc_mich's Avatar
might be the fork that moves the clutch.. my civic had this.. they had to grease it up from time to time.. also it might be the spring on the clutch pedal.. also civic had the same problem.. a little silicone spray up into that spring always quieted it down.. the fork in the clutch area? not sure about that, usually a little grease from the mechanic stopped that.. hope that helps..
if it's stil under warranty, the dealer should help ya out..
Old Jan 14, 2005 | 07:34 PM
Daemon1313's Avatar
It could be you're throwout bearing. The basic symptom of a failing throwout bearing is a squealing or grating sound when the clutch pedal is pressed and held.
Old Jan 18, 2005 | 10:49 AM
i'd rather have a squeeking clutch then a slipping clutch like me lol
yhwhdesign
Jun 11, 2021 03:34 PM
a23r
Feb 1, 2016 04:05 AM
carbinefreak
Sep 24, 2015 02:06 AM
Mjdavis1994
Sep 21, 2015 04:42 AM
scionsux
Sep 2, 2015 05:30 AM
