17x8 +25?
Old Jul 17, 2009 | 01:17 AM
RCZDesigns's Avatar
Default 17x8 +25?
On a 225/45 tire, will i need to mess with the camber on the rear to run such a low offset?
I know I will need to roll the fender lips, but I dont want to mess with the camber. Also the rear is very low, like 0 finger gap especially when im sitting in it
Im within stock camber specs and want to keep it that way :\
Old Jul 17, 2009 | 01:36 AM
Air2TheThrown's Avatar
I'm not sure with that specific offset, but I have 17x7.5 +33front and +28rear. Rolled fenders and 1.5degree camber all around, only rubbing in rear with 4 people total in car. I have have 225/45 tires also.
My guess is you'll rub unless you have at least 2degree camber because a 8" width with 25 offset you'll be more aggressive than my setup.
Old Jul 17, 2009 | 01:38 AM
RCZDesigns's Avatar
i kind of figured, cause right now I can barely put my finger between the tire and the fender lip. And I have a verrry slight tire stretch.
Pushed out 10mm, even with rolled fenders, i am thinking i am going to be rubbing sidewall constantly on the metal. Sigh
Old Jul 17, 2009 | 05:12 AM
Thorium06's Avatar
pull the fenders, and add negative camber, but please dont stretch
Old Jul 17, 2009 | 05:18 AM
davedavetC's Avatar
dont pull the fender, just roll them, and at a little more neg camber you'll be fine
Old Jul 17, 2009 | 05:24 AM
Thorium06's Avatar
but with pulling you could run some 245's!
Old Jul 17, 2009 | 05:25 AM
davedavetC's Avatar
and if done wrong your hundreds of $$ in for fender repare, keep the tires you have and run a little camber and just roll the fenders.
Old Jul 17, 2009 | 06:01 PM
RCZDesigns's Avatar
ugg i dont want to run any camber, im already barely within stock specs and want to keep it that way for safety reasons. I ride with people in my car alot more often now so i got other people to worry about.
thanks for the help guys, looks like ill be going with 5mm spacers instead, and just roll if i need to. i just wanted a more noticable before/after, lol
xBrelease08
12
Feb 29, 2016 05:39 AM
satoman44
Scion tC 1G Wheel & Tire
16
Apr 15, 2007 03:32 AM
irwin07
Jan 10, 2007 04:07 AM
bBOXD
44
Jan 31, 2006 07:13 PM
stankubrick
Aug 26, 2004 10:38 PM
