TSB repair work done
Old Jan 26, 2005 | 02:47 AM
Orataro's Avatar
Default TSB repair work done
Being work has been slow, I decided to take my xB in for a few TSB work.
First one was for the fuel pipe opening. In my case, the Fuel tank and pipe opening were replaced along with other parts. Basiclly, the whole gas tank had to be replace. Cost of parts, $625.70
Second TSB work was for the A/C. Again, in my case, the whole A/C unit had to be replaced. Total cost of parts $1242.70
In all, total cost of the two TSB's were $1,868.40 and covered by factory warranty.
Right after leaving the dealer, I had to fill up with gas. OMG! What a differance. It's the first time in over a year I didn't have to put the gas pump on the first notch.
My A/C is so cold that I find myself wanting to turn on the heater.
I also found that my xB seems to run much faster/quicker. This just might be in my head?
Take advantage of your TSB's.
Old Jan 26, 2005 | 03:07 AM
TheKnown's Avatar
yea the only thing nicer about the tsb is when the messup and install a supercharger in my car instead of fixing the pop in my moonroof..... ahhhh a tC owner can dream no?
~MC
Old Jan 26, 2005 | 04:29 PM
superjeer's Avatar
"OMG! What a differance" yeah, I'm livin large too! nice huh? I might get the AC one done in spring. Kinda nervous though.
Old Jan 26, 2005 | 05:30 PM
mikochu's Avatar
Dang! I want these TSBs for the xA!
Old Jan 26, 2005 | 08:48 PM
jct's Avatar
jct
how long did it take you to get you TSB's done, and did you get a loner car too??? i'm taking mine in 01/31 monday to get these done and for the rattle too
Old Jan 26, 2005 | 09:16 PM
Orataro's Avatar
I took the car in at 7:00am and it was done by 5:00pm. I also had my oil changed and had them look at my rear bumper as it had came lose. No loaner was required or should I say I didn't request one. They just gave me a ride home and picked me up.
Old Jan 26, 2005 | 10:04 PM
George's Avatar
Default Re: TSB repair work done
I'm going to get mine done when the weather warms up so I can do a comparision of AC function. No trick to getting it blowing cold when it's 60 degrees outside! My filler has always been marginal so that one will get done too. I suppose I was more tolerant of the filler since it would usually run full blast until the last couple of gallons. then you had to eaaasseeee them in.
Did you have the work done here in the SCV?
Old Jan 26, 2005 | 10:32 PM
Sid_xBicious's Avatar
on the AC TSB, does anyone knows until when is the warranty covered? I want to do this by or before summer, I hope its still covered by then.
Old Jan 26, 2005 | 10:34 PM
Scott17's Avatar
StyleWagons
Old Jan 27, 2005 | 12:32 AM
silkywilson's Avatar
I think TSBs are forever,., it isnt a warentee issue.. however its also not a recall.. so they are not "required" to do the work.. just do them ASAP while its fresh
Old Jan 27, 2005 | 12:45 AM
XBman's Avatar
how much is the a/c tsb.... like alot better? is it worth it?
1-10 rating
Old Jan 27, 2005 | 01:03 AM
rallyxb's Avatar
First one was for the fuel pipe opening. In my case, the Fuel tank and pipe opening were replaced along with other parts.....
I posted info for a lot of TSB's a while back at:
"xA, xB, tC: Technical Service Bulletins"
https://www.scionlife.com/forums/vie...776&highlight=
I thought I had found them all, but the fuel pipe opening I do not have.
Can you please post a link or E-amil me the PDF file?
Also, is there a TSB for the chipping, scratching paint?
Thanks!
Old Jan 27, 2005 | 01:43 AM
there should be a tsb for paint but there isnt , oh well , one day. and the gas tank tsb is for both xa/and xb
Old Jan 27, 2005 | 02:16 AM
FrankenScion's Avatar
I got my fuel TSB fixed today also. Took about 2 hours.
Here's a link to the page I found the TSB on, Rally.
http://www.club-swat.com/~scion/Scion.htm
Old Jan 27, 2005 | 04:48 AM
Sciond's Avatar
did I miss the fuel tsb?????
Old Jan 27, 2005 | 05:02 AM
Al-Truistic's Avatar
What is the fuel TSB under and when you brought it in for this problem what did you say to explain the problem: did you just give them the TSB number or did you say you were having problems pumping gas?
Al.Truistic
aB
Old Jan 27, 2005 | 10:51 AM
all ya gotta do is bring it in and ask if your car is covered for the gas tank tsb , and if they ask just tell em it's hard to pump without clicking.
Old Jan 27, 2005 | 01:04 PM
Orataro's Avatar
I just played dumb. I told them I had trouble putting gas in and told them I had heard of a TSB.
Old Jan 27, 2005 | 01:50 PM
Fujiz_xb's Avatar
okay what is this TSB talk about.. ??? why and why?
Old Jan 27, 2005 | 04:17 PM
this has been discuss for months now. its about how some of us were having problem pumping gas with out the nozzel clicking even if the tank is not full, or even you just started to pump. some recommend changing the position how you put the nozzel. but some of us still gets difficulty pumping gas. Toyota realize it and issue TSB. then we go to dealer to see if our VIN qualifies and they order the parts and do the job.
