TSB repair work done
sIcKsCiOnS
Being work has been slow, I decided to take my xB in for a few TSB work.
First one was for the fuel pipe opening. In my case, the Fuel tank and pipe opening were replaced along with other parts. Basiclly, the whole gas tank had to be replace. Cost of parts, $625.70
Second TSB work was for the A/C. Again, in my case, the whole A/C unit had to be replaced. Total cost of parts $1242.70
In all, total cost of the two TSB's were $1,868.40 and covered by factory warranty.
Right after leaving the dealer, I had to fill up with gas. OMG! What a differance. It's the first time in over a year I didn't have to put the gas pump on the first notch.
My A/C is so cold that I find myself wanting to turn on the heater.
I also found that my xB seems to run much faster/quicker. This just might be in my head?
Take advantage of your TSB's.
sIcKsCiOnS
Originally Posted by hornet_on_flower
how long did it take you to get you TSB's done, and did you get a loner car too??? i'm taking mine in 01/31 monday to get these done and for the rattle too
Did you have the work done here in the SCV?
First one was for the fuel pipe opening. In my case, the Fuel tank and pipe opening were replaced along with other parts.....
I posted info for a lot of TSB's a while back at:
"xA, xB, tC: Technical Service Bulletins"
https://www.scionlife.com/forums/vie...776&highlight=
I thought I had found them all, but the fuel pipe opening I do not have.
Can you please post a link or E-amil me the PDF file?
Also, is there a TSB for the chipping, scratching paint?
Thanks!
I got my fuel TSB fixed today also. Took about 2 hours.
Here's a link to the page I found the TSB on, Rally.
http://www.club-swat.com/~scion/Scion.htm
What is the fuel TSB under and when you brought it in for this problem what did you say to explain the problem: did you just give them the TSB number or did you say you were having problems pumping gas?
Al.Truistic
aB
Al.Truistic
aB
Originally Posted by Fujiz_xb
okay what is this TSB talk about.. ??? why and why?
