Oy! Injen SR intake install...
Old Feb 8, 2005 | 05:57 AM
CrushXB's Avatar
Default Oy! Injen SR intake install...
Quick question what the heck do I do with these bolts? I tried everything I got and I couldnt get em loose. what gives?
These are the 3 bolts at the bottom of the stock filter box. I was trying to remove it to install my intake but the bolts wouldnt budge. Any ideas?
Old Feb 8, 2005 | 05:58 AM
squirrel's Avatar
Breaker bar and an extension.
Old Feb 8, 2005 | 06:40 AM
flowmini98's Avatar
should be like a 10mm socket ...get a long ___ extension and put some force behind it.
unlmtdndeavor's Avatar
and if that breaker bar and extension dont work, maybe someone played a prank on you and super glued those in, cuz they arent supposed to be that tight...try a can of spinach
Old Feb 8, 2005 | 07:05 AM
djct_watt's Avatar
Team Sushi
Are you turning counter-clockwise? It's attached to a plastic filter housing. . . if they over torqued the bolts, they would have cracked the filter box.
Old Feb 8, 2005 | 07:07 AM
djct_watt's Avatar
Team Sushi
I'm not trying to be a wise ___, just making sure. . .
Old Feb 8, 2005 | 03:26 PM
Dewmerz's Avatar
Just a thought but if the car had been driven right before you started the install it may have been hot enought to make the bolts harder to come out. Just a guess since I hardly even trust myself sometimes.
Old Feb 8, 2005 | 04:37 PM
CrushXB's Avatar
The Car had been driven. I didnt have a breaker bar so I had to come up with one and I busted my roomated cheep socket wrench The car was driven prior to install so maybe heat. I am thinking I just need a real breaker bar. I will have to pick one up it looks like.
Thanks all.
PS Yeah I was turning counter-clockwise.
PSS Yes I tried a can of spinach
Old Feb 8, 2005 | 08:02 PM
its_ikon's Avatar
1. moved to power hungry incase this comes up for someone else
2. it is a 10mm and it shouldn't be that hard to get off. i have small hands, so maybe if you large hands find someone with small hands and see if they can do it
Old Feb 8, 2005 | 08:37 PM
yeah mine wasnt that tight at all. just wait for it to cool.
Old Feb 8, 2005 | 08:58 PM
KingLou's Avatar
The other solution is to just leave it there. That's what I did. I left the stock airbox........just removed the piping that was in the way.
KiL
Old Feb 8, 2005 | 09:50 PM
NCP31's Avatar
Jason,
Just bring it by the shop and we'll get it installed.
Old Feb 9, 2005 | 03:03 AM
bB86gts's Avatar
spray with wd-40 and let it sit for a bit..usually does the trick, although when i did my install, just pulled in from driving 40 mi from work....didnt give me any trouble at all..
just try the wd-40.
hope this helps.
JP
Old Feb 9, 2005 | 08:28 AM
hnefrdo's Avatar
for most stubborn bolts, a WD40 drench or a few taps with a hammer will do the trick.
Old Feb 10, 2005 | 07:26 PM
Chimmy3's Avatar
for a few minutes i was wondering if spinach oil loosens up the bolt or something... then I caught the reference...
my bolts weren't that tight, and i drove my box around quite a bit before putting the intake in.
i'd say devise an extension to clear the box... you may need a friend to help press downwards.. I borrowed my mechanic friend's tools so maybe you need some higher quality tools (the kind that don't break)
Old Feb 10, 2005 | 10:02 PM
jct's Avatar
jct
use a hammer on the wrench(tapping on it) while applying torque on it that might help too
Old Feb 10, 2005 | 10:55 PM
OdBox's Avatar
I used a ratchet with a SHORT 2" handle and a 2" extention. No extra force needed.
Old Aug 25, 2005 | 11:23 PM
scion_xb_guy_05's Avatar
*****does anyone have a PDF of the install of the SR injen intake!? i am loking to install it but i dont have the instructions... pm me if you have them!!! thanks a lot!!!*****
steeze69
May 24, 2021 02:57 AM
carid
Feb 10, 2019 10:46 PM
Nkelly
Sep 7, 2015 05:06 PM
