Running Multiple HID kits
Old Dec 10, 2009 | 06:21 PM
karatekidd's Avatar
Default Running Multiple HID kits
Hey guys,
I'm running a set of HIDs in my 08 headlights, both headlight harnesses are being used.
I've ordered a set of 3K HIDs for my fogs...then I realized....how will I get these to power up?
I've got APT/VRD fogs and I need some input...
Of course I searched, but after 2 hours, I was hoping I could ask someone who is running something similar.
Thanks SL.
Old Dec 10, 2009 | 06:28 PM
Joyride's Avatar
Uhm use the fog light connectors. Fog light connectors > Hid Connector (that connects to the ballast) ((they are Pos and Neg wires) Then from the ballast you connect the HID bulb.
Old Dec 10, 2009 | 07:50 PM
capicu23's Avatar
I got the same setup as you want. Just make sure you use 2 sets of harnesses and you'll be good. Remember if you got a harness that connects to the battery + & - it only uses one oem plug to light up 2 ballast. So lets do the math, 4 ballast + 2 harness = vrd and headlight HIDS!!!!!!
Old Dec 10, 2009 | 07:53 PM
Jon's Avatar
Jon
Moderator
Moderator
You'll need to buy a relay harness since the fogs split off from one connector. I'd suggest getting one for your low beams also just to be on the safe side.
Old Dec 10, 2009 | 09:40 PM
karatekidd's Avatar
Awesome, I appreciate it guys!
I'll post again once it's done...
mvez
Scion tC 2G Aero & Exterior
Feb 4, 2015 01:15 AM
jaspercanda
Dec 28, 2014 10:09 AM
Basebllstar
Dec 17, 2014 07:30 PM
minter66
Dec 15, 2014 01:45 PM
umnitza
Dec 1, 2014 06:26 PM
