xb rear wheel alignment..
Old Feb 14, 2005 | 05:40 AM
squarepants's Avatar
Default xb rear wheel alignment..
did anyone need there rear wheels alignment after lowering,took my box in for alignment and they told me that the rear needs alignment too,i'll sure will like to know if this dude is trying to hustle me...
Old Feb 14, 2005 | 06:26 AM
jct's Avatar
jct
i think that four wheel alignment is the norm now-a-days
Old Feb 14, 2005 | 06:29 AM
thanks for the info...
Old Feb 14, 2005 | 12:27 PM
DJ_X_Trodinaire's Avatar
moved
Old Feb 14, 2005 | 02:55 PM
Tamago's Avatar
i dont know what adjustments they they they'll be doing to the back, but there's not really anything back there TO adjust.
Old Feb 14, 2005 | 03:23 PM
^^^ true!
Only thing that needs to be adjusted is the toe of the front two wheels. When I had my alignment done, the left wheel was off by .30
Old Feb 15, 2005 | 03:17 AM
Eski628's Avatar
when i got my xA re-aligned they only adjusted the toe. the camber isn't adjustable with the stock struts and springs.
Old Feb 15, 2005 | 04:15 AM
CBSIMONSEZ's Avatar
The rear is a solid axel, to the best of my knowledge, there isnt anything to adjust.
BTW .... one side of the rear is off, more then the other. If you look at the rear, the drivers side sits in more then on the passengers side. By about 5MM. All the boxes have this problem, its normal for some reason. They came this way from the factory.
Old Feb 15, 2005 | 04:27 AM
it's true there is nothing to adjust on the rear but the guy at the shop told me that you can install shims on the hub so the wheels will sit level on the ground,think i'll do the alignment to the front for now as for the rear i'll wait and see what kinda tire wear i'm getting..
Old Feb 15, 2005 | 07:41 PM
George's Avatar
I can understand the idea of the shims, but I can't see any way that raising or lowering the suspension can change the alignment. With both spindles attached to the same swingarm the axles have to be parallel (actaully, coaxial) to each other throughout their travel.
George
Old Feb 15, 2005 | 08:02 PM
Tamago's Avatar
castor will change..
but not much you can do about that..
Old Feb 16, 2005 | 02:04 AM
mach5's Avatar
and camber wil change if you don't know what your doing
kleecker
9
Aug 2, 2022 05:00 AM
Miqmiqmiq
Jan 15, 2015 03:30 AM
tapetheducks
Jan 14, 2015 06:25 PM
Slopoke21m
54
Apr 23, 2007 12:25 AM
scionara
38
Feb 25, 2004 04:52 AM
