ODometer Help!
Old Feb 6, 2010 | 06:49 PM
DJ_FroZone's Avatar
Default ODometer Help!
So i took the headunit dash from the my 08 and put it into my 2010. But the odometer is still the same! it shows 39,000 when my current car only has 410. how do i reset that Ecu to represent actual mileage?
Old Feb 6, 2010 | 06:56 PM
draxcaliber's Avatar
you can't. the odometer mileage is stored in the gauge cluster.
Old Feb 6, 2010 | 08:30 PM
DJ_FroZone's Avatar
crap. so what do i do? i have a custome gauge face and LEds inside this one. or can i possibly switch the CPU's out?
Old Feb 6, 2010 | 10:26 PM
AAG's Avatar
AAG
DeepSouth Scions
How were you able to keep your guage cluster from your old one? Insurance would have never allowed that.
Old Feb 6, 2010 | 10:50 PM
DJ_FroZone's Avatar
Well they took 100 or so out of the check. I have the blue led mod and faceplates. So I took it out the ride.
Why?
Old Feb 6, 2010 | 10:57 PM
SquallLHeart's Avatar
they would've needed it to sell the car unless it was completely totaled and couldn't be salvaged.
you have to switch the gaugefaces over and get the new gauge cluster swapped out.
there is no way you're going to get the old cluster to display the correct mileage.. and switching whatever flash memory over will be more difficult than just swapping the leds.
Old Feb 7, 2010 | 12:00 AM
DJ_FroZone's Avatar
Yea it was totaled. So I removed it. Now in sad those lil leds where a pain in the **** hopefullyy I can de solder
Old Feb 7, 2010 | 12:34 AM
DJ_FroZone's Avatar
What about inplugging the battery and hooking it up again. Would that reset the chip again like it does the clock?
Old Feb 7, 2010 | 03:00 AM
pyroman131's Avatar
Probably not. Imagine what a pain it would be if every time your battery died or if you disconnected the terminals that your odometer would reset. I think Toyota would prevent that from happening. There's probably some high performance battery system that backs up the odometer information in that gauge cluster.
Old Feb 7, 2010 | 08:27 PM
buickid's Avatar
Probably uses non-volatile memory. The odometer is designed to be extremely hard to tamper with. If you try, the thing might go into lockdown and display ERROR or something. Then you'll be stuck with a expensive paperweight.
Old Feb 7, 2010 | 10:13 PM
slowdalpangee's Avatar
try asking the dealer if they ahve any ideas? just don't mention your name or anythign specific like that
Old Feb 8, 2010 | 04:33 AM
creamyxb2's Avatar
the gauge control modual will need to be sent out. they have to reburn the milage in the old one.im not a scion tech but thats what they tell me. i m an acura tech and i can do acura ones with a computer in about 5 mins. so the 2010 may be different.
Old Feb 8, 2010 | 09:31 AM
DJ_FroZone's Avatar
Im going to try that one creamy!
Klunkerbill
Nov 9, 2015 11:39 PM
chenboly
May 29, 2015 06:59 AM
Basilius
9
Jul 13, 2006 05:44 AM
midtowndesi
Nov 25, 2005 06:19 PM
RussianTC
Jul 27, 2004 04:21 AM
