shift knob for automatic
Old Feb 15, 2005 | 03:42 PM
Fujiz_xb's Avatar
Default shift **** for automatic
will the following item work for automatic?
it says univeral but our button is on the side.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33703
Old Feb 15, 2005 | 03:52 PM
Lonely_Raven's Avatar
I think the way the side button works, is that it pushes a
shaft with a plastic nub at the end that's cut at a 45 degree
angle. So technically the button is verticle under your stock
Take your stock one off and see before you order me thinks.
Old Feb 15, 2005 | 04:02 PM
SWiSS's Avatar
that would be sick! IM not sure either though. wish i could be of more help...
Old Feb 15, 2005 | 04:05 PM
GINNJUICE's Avatar
i think it would work but how about the overdrive button.
Old Feb 15, 2005 | 04:06 PM
Fujiz_xb's Avatar
over drive? do we even need that?
Old Feb 15, 2005 | 04:14 PM
dirtysocks's Avatar
i got one of thoses along time ago and do you think it could work as a ebrake **** i havent tried yet?
Old Feb 15, 2005 | 04:23 PM
Fujiz_xb's Avatar
so it does work correct?
Old Feb 17, 2005 | 04:18 AM
koalaty2's Avatar
If it fits, would look great. I just covered mine to match new interior. Black/White.
Old Feb 17, 2005 | 04:52 AM
timinaz's Avatar
I think the overdrive button could be moved, it's only a switch.
Old Feb 17, 2005 | 05:11 AM
squarepants's Avatar
looks cool but i'll wait for one of you guys to try it out first.........
Old Feb 17, 2005 | 06:29 AM
Minsk99's Avatar
I switched automatic ____ ***** on my xb. Raven is right about the button technically being vertical. Also, I moved my old button to a location under the ebrake handle. I also have the button on the new **** hooked up as well. So theoretically the **** could work, its just a question of if it comes with the right adapters to fit our oval bar.
Old Feb 17, 2005 | 06:42 AM
They sell e brake handles you know.
Old Feb 17, 2005 | 05:21 PM
LowProMofo's Avatar
Here's an auto shift ****:
He moved the OD button to the cup holders. I also found this one with a OD button on it.
http://www.obxracingsports.com/inter...2&subCat2ID=20
I posted this a while back and found some that may work:
https://www.scionlife.com/forums/vie...924&highlight=
Old Feb 18, 2005 | 12:13 AM
Fujiz_xb's Avatar
well mine didnt work. it didnt fit. so imma return it and i accidentally cut the o/d wires. so i messed up..yes i did..
instead of calling me a dummy any help to figure out which wire is which? they both have polka dots so that doesn't help.
Old Feb 18, 2005 | 01:27 AM
rcstprez's Avatar
I would guess those wires run either way. All the button is, is a switch that allows current (or a ground) to pass through to close a circuit, and engage or dis-engauge the OD.
MattB
Old Feb 18, 2005 | 01:35 AM
killerxromances's Avatar
Well, i've actually tried to swap shift **** for my automatic and i didn't like how it was set up so i returned it and put the stock one back on. If you want the O.D option, you'll need to re-locate it to a different position. If not, you'll need to either wire it to be left on or left off. With an automatic, if you are doing a lot of interstate driving i would recommend it left on. But its also nice to have that option because you never know when you'll need it...or not need it.
Old Feb 18, 2005 | 02:52 AM
LowProMofo's Avatar
I agree, I do use mine when I need it. These aren't the fastest cars in the world. I need my OD for passing people most of the time. If I do buy an aftermarket Auto **** I'll relocate the ODB somewhere.
Old Feb 18, 2005 | 04:04 AM
Yeah, probably the best place to re-locate it would be either right there by the E-brake or cup holders. That way you aren't going all throughout the dashboard just to re-locate.
Old Feb 18, 2005 | 06:40 AM
Minsk99's Avatar
Yup. It seems most aftermarket auto ***** don't have the same "action" as the stock. What I did was to splice into the stock OD wires. I hooked one set of wires to the new ***** button and the other I ran under the center cup holder boot (what ever its called) and mounted under the ebrake handle. Both work. I prefer the "action" on the stock button and use it if I have to turn off od quickly. Its actually a convenient location especially if you have an aftermarket armrest because your hand is resting right there.
either way will work.
Scionxa180
Sep 24, 2015 03:51 AM
Jvg2727
Scion xD Drivetrain & Power
Aug 24, 2015 04:40 AM
ScionLife Editor
Aug 6, 2015 06:12 PM
stenger
Jul 15, 2015 01:03 AM
SFXB
Jul 9, 2015 11:00 PM
