Weapon R CEL
Old Feb 19, 2005 | 12:48 AM
yellot00tr's Avatar
Default Weapon R CEL
i just put in the weapon r secret weapon intake, it threw me a cel. pretty sure i did everything right, let it idle for like 10 minutes also. anyone got anyone suggestions other than saying that they think weapon r sucks-i already bought it, so that wouldn't do me any good hearing it.
Old Feb 19, 2005 | 01:03 AM
TheScionicMan's Avatar
Did you wipe out the insides of it before installing? I don't know about this one specifically, but I've heard some intakes have a slight coating of oil inside and this can foul the MAF sensor. You could try cleaning the MAF with some cleaner made for electric parts and wipe the inside with a clean cloth.
Old Feb 19, 2005 | 01:06 AM
PandaIst's Avatar
Someone else had this problem recently. I think he contacted weapon r directly to find out how to fix the problem.
Old Feb 19, 2005 | 05:29 AM
hahaitzskippy's Avatar
after you let it idle for 10 mins... did you drive it hard afterwards?
Old Feb 19, 2005 | 07:05 AM
yellot00tr's Avatar
i reset the ECU and let it idle for 20 minutes, and after 45 miles, so far it seems to be working ok(no CEL). hopefully that's the problem-i didn't idle long enough for the ECU to get used to the extra air flow.
Old Feb 19, 2005 | 07:11 AM
KYBoy's Avatar
Scion Corps
DeepSouth Scions
hope it works
good luck
Old Feb 20, 2005 | 01:09 AM
yellot00tr's Avatar
just got the CEL again. worked for 100 miles, and back on again. i just added the TRD intake(props to NYCAZN-for the ill hook up) and it went for 100 miles and came back on. i found out the the code is for the engine being LEAN. anyone have any ideas how to fix this?
Old Feb 20, 2005 | 01:11 AM
yellot00tr's Avatar
the code was P0171 - system too lean.
Old Feb 21, 2005 | 05:34 AM
WeaponR_Ray's Avatar
We recently had a minor redesign to fix a lean condition CEL. Contact me about getting this issue corrected.
Old Feb 21, 2005 | 12:00 PM
toyota_scion_tc's Avatar
I just got a Weapon R Secret Weapon intake installed it on the 18th. I have put at least 130 miles on it and have no cel. The only thing I noticed is where the maf sensor installs the o-ring seems small on the intake, it might need a little thicker o-ring. This might fix your problem.
MeDizzy
Oct 8, 2015 03:31 PM
domincnTC
Aug 4, 2015 01:47 PM
BigIrish
May 18, 2015 12:04 AM
xb4lf
Apr 4, 2015 07:15 PM
yellot00tr
20
Mar 8, 2005 07:29 AM
