My Radio Isn't Getting Power
Old Apr 27, 2010 | 02:44 AM
randomsuper's Avatar
Default My Radio Isn't Getting Power
so i installed a new stereo system in the car and now i'm having 2 minor issues. my radio isn't turning on. i used a test light and verified that there is no power present. no fuses have been blown either. so now i'm stumped. any idea what it might be?
also, my fog lights aren't turning on. haven't really checked anything with that yet. trying to figure out what's going on with the radio first.
Old Apr 27, 2010 | 03:32 AM
Frizz's Avatar
Team ScionTific
Check the fuse box in the engine bay.
Old Apr 27, 2010 | 03:44 AM
that was the first thing i checked. fuses aren't blown.
Old Apr 27, 2010 | 03:47 AM
Frizz's Avatar
Team ScionTific
That's really all it could be. I think the stock radio might have a fuse on the back of it
Old Apr 27, 2010 | 04:00 AM
tCb00b's Avatar
First stop using a test light. Get a digital multimeter I think Harbor Freight has one for about five dollars. For basic 12V you don't need something very complicated to trouble basic car electrical issues.
Check the fuse box in driver or passenger foot well. I'm not sure which side it is on in the xB.
Now on to the install questions, did you buy a vehicle side harness or did you cut the harness that was plugged into the back of the radio?
Also, the aftermarket radio might have a fuse on the back of it. I haven't seen any Japanese cars with fuses on the factory radio itself usually only seen on higher end European cars.
Old Apr 27, 2010 | 04:02 AM
i'm not using a stock radio. like i said, there is no power going to the headunit. it's not the headunit for sure. could it be a cut wire somewhere? i'm totally stumped right now.
Old Apr 27, 2010 | 10:45 PM
xseveredveganx's Avatar
Utah Scions
Make sure the connection from the headunit to the OEM harness is correct and made well. I almost always solder and heat shrink harnesses.
Old Apr 28, 2010 | 02:03 AM
found the problem. wires pulled out of harness equals a bad thing. easy fix though. now i need to figure out the fogs.
wonderworm
Nov 19, 2023 01:44 AM
Inazuma
20
May 3, 2023 01:58 AM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
missing_image
Feb 7, 2015 07:18 PM
crystaljukebox_com
Feb 5, 2004 05:53 AM
