Scion xD Aero & Exterior Aero parts and exterior dress items...
DRL DIY with Pictures
Old Apr 29, 2010 | 10:05 PM
bwhite's Avatar
Default DRL DIY with Pictures
Here is a link to the PDF File of the DIY
http://www.scikotics.com/forums/atta...1&d=1272577105
Hope you can use the info.
EDITED: Sorry the file is larger than this forum accepts.
If you don't have an account there, you can d/l the PDF file here:
http://www.filefactory.com/file/b15f...actory.com</a>
Old Apr 29, 2010 | 10:35 PM
asurjc's Avatar
It wants me to log in. Do I need to register?
Old Apr 30, 2010 | 05:22 PM
Mynam3isazia's Avatar
http://www.filefactory.com/file/b15fh4e/n/DRL_Wiring_DIY.pdf">Download DRL Wiring DIY.pdf from FileFactory.com</a>
thanks so much bro I will try this when I have time really cool
Old May 1, 2010 | 12:14 AM
Zefoxe's Avatar
just curious, why would u want daytime running lights? most ppl i know try to get rid of this on their cars...
Old May 1, 2010 | 05:19 AM
bwhite's Avatar
Default because . . . Looks Kewl
Just cause Difrnt strokes fr difrnt folks
And when it's not there they want it, if it's there, they don't.
Some of us just have to be different
Old May 2, 2010 | 01:41 AM
CXTKRS1's Avatar
Why not just use the parking light switch? DRL systems have a light sensor that controls when the DRL's and headlights come on anyway.
Old May 2, 2010 | 07:02 AM
bwhite's Avatar
When you use the parking light switch, the tail lights are also illuminated and true DRLs have no tail lights illuminated. Just tryin to have it done right. Also, I have my fogs tied to the parking light switch so it makes it very convenient now to have HIDs on with the headlight switch, Fogs on the parking light switch and the DRLs on without anything turned on except the motor, and it goes off when the key is turned off...
Old May 2, 2010 | 09:09 PM
furiousPunch's Avatar
is there some kind of diagram that shows how to set the fogs with the parking lights? im getting fogs soon and want it just like this, and exactly how you're saying with tru DRLs there is no taillight on & thats what im looking for as well
Old May 3, 2010 | 07:04 PM
xDA51's Avatar
Love this, doing this, thank you!
Old May 3, 2010 | 10:15 PM
bwhite's Avatar
Default I'll get you a picture
Soon as I can, I'll get you a picture of where you can attach your fogs.
Old May 5, 2010 | 05:23 AM
bwhite's Avatar
Default Fog Lights On With Parking Lite Power Wiring
Furiouspunch,
Here is the wiring picture you wanted. The taps are on the [black/white] and [green] lines (both are on the same end of the plug connector). The connector is the one just above the headlamp and is clipped to the H/L Housing. Be aware of POLARITY and check with a DVM before you connect to your fogs. If the fogs are fillament bulbs it probably won't matter which you use as long as the foglight circuit does not use a ground connection to the assembly. If you are using the blocked out vents there is most likeky no ground since the entire bumper is made of plastic. Good Luck with your project !
Aloha From Hawaii
Old May 16, 2010 | 09:31 PM
sommerz's Avatar
filefactory isnt loading/working for me..
Old May 18, 2010 | 12:18 AM
bwhite's Avatar
Default FileFactory
Try copying the link, and pasting it in the address area of internet explorer.
Some versions of Chrome have problems with using links.....
FileFactory IS Alive and well ! (I checked)
good luck
Old May 18, 2010 | 05:05 AM
Julian_xD's Avatar
I couldn't get into filefactory too even though I had to create an account.
Old May 18, 2010 | 08:15 AM
bwhite's Avatar
Default another link
This might work for you who can't get there...
That's wierd, it must be blocked by your ISP.
http://www.mediafire.com/download.php?rdw1lmnxx23
Old May 18, 2010 | 10:34 PM
asurjc's Avatar
This link worked for me finally too thanks! When you did this, you actually replaced your parking lamps with brighter led's and moved the parking lamp pins completely right? So does anything happen now when you have the key off but the parking lamp switch on? I'd like to do this but would still like to have some kind of low-level front light to function as a parking lamp with the key off. Is this possible?
Old May 19, 2010 | 02:22 AM
bwhite's Avatar
Default Can Do however...
You would then have to put an external switch so that you can go from (a)the shown modified connection or (b) a live 12v source and the common to your parking lamp pins (2 green wires) That would enable to have your new, led lamps on when thekey is off. What you'd need would be a DPST switch which could be like 3 bucks at RadioShack.
That would enable you to power the parking lights when the key is off, since what I have is altered the circuit to fire up without having the tail lamps on. It is really bypassing the parking light switch, so that the Tails never illumiate with that setup. (you will need to then, turn on 2 switches, since the tails will come on without the front lamps wusing the blinker stick parking light switch.
SoKrispy
Scion tC 2G Aero & Exterior
Oct 13, 2015 03:48 PM
mischman
Sep 15, 2015 03:38 PM
Ways808
Aug 2, 2015 08:13 PM
Latexbullet
Jul 21, 2015 04:02 PM
SoCal_CJ
Scion tC 1G ICE & Interior
Jul 14, 2015 09:14 PM
