rear suspension noise?
Old Feb 26, 2005 | 10:32 PM
wooish's Avatar
Default rear suspension noise?
When I get in or get out of the car I would hear the suspension making squeaky noise in the rear. Is this normal on the xB or is there something wrong with it? It also happen if I jacking up/lowering down the car.
David
Old Feb 27, 2005 | 01:07 AM
unlmtdndeavor's Avatar
it is not out of the ordinary. are you on stock or aftermarket springs. jacking the car up will make them squeak for sure
Old Feb 27, 2005 | 01:41 AM
Sublimize23's Avatar
I notice it on mine too.
Old Feb 27, 2005 | 03:21 AM
MotoMan_YZ400's Avatar
well mine does that and so does my friends echo.... i found it to be the parking break... when you sit in or get out of the box, the suspention raises up, and w/ the rear end having a swingarm style to it, when the suspention goes up or down, it will almost push the rear wheels, causing the the Pbrake to slip or chatter slightly in the drum (kinda like if your on a hill stopped and have the break in, slowly let it out, you can make the breaks chatter at VERY slow speeds) Try getting out/in/jumping what not w/ the Pbrake down, it will go away.... i dont like it, almost make the car sound cheap or POS like.... but to solve, either dont use the Pbrake, or pull it up higher.....
Old Feb 27, 2005 | 01:07 PM
mikem53's Avatar
Default Re: rear suspension noise?
David
Sounds like a possible bushing noise. They make a greese for this...
Take a look under there to be sure nothing is loose.. otherwise nothing to be concerned about.
Old Feb 27, 2005 | 04:07 PM
wooish's Avatar
thanks for the reply guys. This noise happens since day one so maybe it's normal.
Old Feb 28, 2005 | 01:13 PM
mynameisphunk's Avatar
mine happens all the time. worse when it's cold. parking lot speeds i hear it going over bumps etc..., 22k on my '04 xB, been happening since i got it.
Old Mar 3, 2005 | 02:14 AM
its_ikon's Avatar
i have had it happen also, but i have aftermarket wheels
carid
Feb 12, 2015 11:54 AM
evolving_machine
Jan 13, 2015 08:04 PM
toyotaisme
Jan 10, 2015 10:24 PM
MosFed
Dec 27, 2014 03:24 PM
jjambox
26
Dec 8, 2005 11:19 PM
