Help! Car loosing power!
Old Feb 28, 2005 | 05:21 PM
vpkb's Avatar
Default Help! Car loosing power!
After my trip back from San Francisco, I noticed my car loosing a lot of power. Will not rev past 4000rpm and very hard to get to 90mph.
Acceleration is very slow and sluggish, car will not respond even when flored. I thought it needed a fresh oil change but it didn't make a difference.
What can be the problem? Please help.
Old Feb 28, 2005 | 05:25 PM
TheKnown's Avatar
tranny
Old Feb 28, 2005 | 05:35 PM
BoxCarWillie's Avatar
Sounds like a fuel delivery problem... I don't own an xB yet but prehaps the fuel filter is plugged (perhaps you got some bad gas and it plugged the filter).
I'd have the dealer plug it in and see if there are any codes.
Perhaps this is a blessing in disguise...my guess is that if you hit something (or got hit by something) at 90 mph in an xB you'd be SOL...
Old Mar 2, 2005 | 11:16 PM
XBman's Avatar
dealer..... get it checked out
Old Mar 3, 2005 | 02:54 AM
Metro273's Avatar
Default Re: Help! Car loosing power!
Sounds like to me a BAD mass airflow sensor? I'm a Nissan mechanic and our Maximas and Sentras are notorious for these exact symptoms you mentioned, especially if it's an auto tranny...
Old Mar 5, 2005 | 11:49 PM
firesquare's Avatar
WARRANTY is your friend
Old Apr 7, 2005 | 02:00 AM
TheQuietThings's Avatar
sounds like another fuel delivery problem. hopefully you didnt get bad gas or anything because that could clog it. besides that, are your fuel injectors clean? spark plugs alright?
Old Apr 11, 2005 | 06:08 AM
Plague's Avatar
I had the same problem. I noticed after I had gone on a bumpy ride. Check to see if your air filter hose are connected and check to see if your air cleaner is not opened. That happened to me. Or even better get rid of your air box and go cold air intake. Talk to you later Plague..
Old Apr 11, 2005 | 03:31 PM
JasonH's Avatar
Sounds like the ECU is in "limp mode". A number of things could cause this, most likely bad readings from an MAF or O2 sensor. Have a dealer check it out.
mdhyre
Dec 7, 2014 12:52 AM
fur_pig
Dec 5, 2014 12:48 PM
cwong1001
Dec 3, 2014 03:30 AM
nacy333
44
Oct 4, 2009 11:18 PM
tC_Normo
Oct 22, 2003 07:20 PM
