Scion Factory Neon.
Old Aug 7, 2010 | 06:15 PM
headlessmunky's Avatar
Default Scion Factory Neon.
The factory neon for under the dash and in the cup holders stopped working, i would care so much but my cigarette lighter doesn't work either. So no charging my zune, or radar detector. I went on a trip to NY it worked on the way up but after we grabbed so food and started back it stopped somewhere in between there.
Old Aug 7, 2010 | 06:16 PM
Question is what could have caused this and where is the fusebox for this car!
Old Aug 7, 2010 | 06:37 PM
RoboCop's Avatar
Fusebox is next to the battery. Diagram in on the lid.
Old Aug 7, 2010 | 07:06 PM
joshuabowman's Avatar
It's inside the car by the driver's door. It's behind the hood release under the dashboard.
Old Aug 8, 2010 | 05:08 PM
It the under-dash and cup holders. Thanks im going to go check it out.
Old Aug 8, 2010 | 07:17 PM
Update looking for the cigarette lighter fuse. The wonderful people at scion tapped the wire off the cig lighter for it. Prolly on the stock fuse too.
Old Aug 12, 2010 | 10:17 PM
willerdcraft's Avatar
sounds like fuse issue the ciggarette lighter uses a
15amp (No # 25 in the fuse box) and it is in the interior fuse box on the drivers side by your left knee.
If you are lucky you should still have some spare fuses in your under the hood fuse box i belive there is a spare 15 amp in the fuse box lid.
Old Aug 12, 2010 | 10:34 PM
pOrk's Avatar
Sounds like a fuse to me as well
Old Aug 13, 2010 | 01:35 AM
Yes it had a 10 amp fuse in it? Also when they tapped the wires the first time they left two of the hole unshielded and i believe they touched causing the problem. fixed, thanks for the help!
herwig
Scion tC 1G ICE & Interior
Mar 23, 2015 04:19 AM
AbsoluteRedtC
Dec 31, 2014 06:18 PM
lunchbx05
Dec 29, 2014 07:53 PM
minter66
Dec 15, 2014 01:45 PM
lunchbx05
Dec 11, 2014 06:13 PM
