Scion Factory Neon.
The factory neon for under the dash and in the cup holders stopped working, i would care so much but my cigarette lighter doesn't work either. So no charging my zune, or radar detector. I went on a trip to NY it worked on the way up but after we grabbed so food and started back it stopped somewhere in between there.
sounds like fuse issue the ciggarette lighter uses a
15amp (No # 25 in the fuse box) and it is in the interior fuse box on the drivers side by your left knee.
If you are lucky you should still have some spare fuses in your under the hood fuse box i belive there is a spare 15 amp in the fuse box lid.
Yes it had a 10 amp fuse in it? Also when they tapped the wires the first time they left two of the hole unshielded and i believe they touched causing the problem. fixed, thanks for the help!
minter66
Dec 15, 2014 01:45 PM
lunchbx05
Dec 11, 2014 06:13 PM
