Just got in my RE Audio SEX12D4, Pictures inside
Old Sep 12, 2010 | 05:35 PM
SparksAI's Avatar
Default Just got in my RE Audio SEX12D4, Pictures inside
This is one hell of a sexy subwoofer. It will be going into my GTO in a custom install next weekend but before it did I wanted to snap a few pics of it's naughty bits.
I have the full line of RE Audio Subs available so if you are interested in putting some serious sound pressure in your Scion let me know.
It is hard to tell from the picture but this voice coil is HUGE
Old Sep 12, 2010 | 07:01 PM
JJGeneral1's Avatar
I feel all tingly inside....
What are the specs? wattage, size, ohm rating?
Old Sep 12, 2010 | 08:14 PM
SparksAI's Avatar
Specs for this one are
Electrical Q Value -Qes: 0.49
Mechanical Q Value -Qms: 4.5
Total Speaker Q Value -Qts: 0.44
Free Air Resonance -Fs: 25.1 Hz
Equivalent Compliance -Vas: 72.9 liters
One-Way, Linear Excursion -Xmax: 18 mm
Efficiency -SPL 1W/1m: 86.1 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 2.8 ohm
Nominal Impedance -Znom: Dual 2/4 ohm
Thermal Power Handling -Pe: 600 W
Force Factor -Bl: 17.7
Mounting Depth - 6.9"
Mounting Hole Diameter - 11.2"
Overall Diameter - 12.5"
Bolt Hole Circle - 11.75"
Motor Width - 7.3"
Motor Depth - 3.44"
Basket Depth - 3.46"
Displacement - 0.15 cu. ft.
You can get them in a Dual 4 Ohm VC or Dual 2 Ohm VC configuration so you have a lot of options to get the right one for your setup.
Old Sep 12, 2010 | 09:15 PM
drkness's Avatar
Very nice. I just got a 10w7. Wired the car, everything all nice and what not and realized that the sub outs on the headunit do not work! tried everything so i guess its back to the dealership to have them take a look at it. ( 2010 HU)
Anyone have any ideas for aftermarket speakers for the doors? Brands? I listen to almost all music, i've had polk, infinity, and kicker in my old car and kicker ks series is the one i like but idk. is there something else out there.
Old Sep 12, 2010 | 10:46 PM
LtBradleykins's Avatar
I don't know if they're even around these days... but what about Phoenix Gold... I know for a long time they were the "way to go" but I also really prefer Boston Acoustics because the cone surrounds are so tight, and they really produce very clear sound. Dunno... just my two cents.
Old Sep 13, 2010 | 02:50 AM
Swbari00's Avatar
Thats a nice looking sub, only concern would be tinsel slap with those tinsel wires not being woven into the spider. I have a DC Audio level 2 on the way that will replace my JL 12W0v2.
PG went the way of most older companies...cheap now.
Old Sep 13, 2010 | 05:58 PM
JJGeneral1's Avatar
do you have one of the head units with the 3 sets of RCA's? if so, it's the bottom set. that sounds like your problem (i hope). good luck!!!
Old Sep 13, 2010 | 10:27 PM
drkness's Avatar
Its the 2010 HU. It only has one set of RCA's and they don't work for anything( highs mids or lows)
dltjdgns66
Scion tC 1G ICE & Interior
Apr 15, 2015 07:59 AM
Beesh
Jan 9, 2015 06:30 PM
lunchbx05
Dec 29, 2014 07:53 PM
minter66
Dec 15, 2014 01:45 PM
Nargrakhan
Scion iQ ICE & Interior
Dec 10, 2014 06:10 AM
