Nitto lower rear strut bar fits!
Old Jan 10, 2011 | 02:14 PM
Nateson's Avatar
Default Nitto lower rear strut bar fits!
Just letting you guys know the Nitto lower rear strut bar for the Yaris fits the XD. I just installed it yesterday. I took it for a quick trip around the block, and to me it feels like it has better turn in now. It's a little harder to install than the TRD sway bar, but that wasn't hard at all. Now my torsion beam is uber stiff. I plan on getting springs and shocks when I get new wheels, but this was just inexpensive and effective. I wanted to go out and play some more with it today, but this white fluffy stuff squashed that. Name:  IMG_0193.jpg
Size:  120.0 KBYou can see I paired this with the TRD sway bar. It fits nicely.Name:  IMG_0195.jpg
Size:  78.0 KB Down here we are not used to this stuff. It closes down everything for days!Name:  IMG_0196.jpg
Old Jan 10, 2011 | 02:24 PM
Nateson's Avatar
Oh, and thanks to Garm at Micro Image for the help and measurements.
Old Jan 10, 2011 | 03:07 PM
ThisorThatxD's Avatar
Looking good. Makes you wonder how many other Yaris parts bolt on for us. Any special fabs needed to get it to fit right or was it really just bolt-on simple?
Old Jan 10, 2011 | 03:24 PM
Nateson's Avatar
It bolted right up!
Old Jan 10, 2011 | 04:13 PM
mixD's Avatar
looks good i might go for this now lol. i have always wondered if a good flywheel or clutch kit for a yaris would fit our car but i do know there are alot of parts that match on one car to the other just have to find what parts those are lol
Old Jan 10, 2011 | 06:42 PM
Nateson's Avatar
You can check part numbers. If they are the same they should fit. Different part number though can be a red flag, but not a deffinate no. Just use common sense. As for questions on parts from micro image, just email him, and he can help.
Old Feb 23, 2011 | 01:39 AM
xdrajicialxd's Avatar
Default installing the rear upper strut bar for the yaris on my xd tomorrow.
i saw this post so i did some research of my own and found that the whole rear strut assembly for the xd is the same as the yaris. so i ordered the rear upper strut bar. I'm installing it tomorrow, pics shall follow. i plan on gettin the rear under strut bar next. that'll complete my frame stiffening upgrades.
this is what i will have:
- strut tower bar
-rear sway bar
-rear upper strut tower bar
-rear under strut tower bar
next is a set of eibach lowering springs.
Old Feb 23, 2011 | 02:55 AM
xDdub's Avatar
Can we install both a rear sway bar and rear lower shock brace?
Old Feb 23, 2011 | 03:42 AM
Nateson's Avatar
Yup, you can see in the pic I have both the TRD rear sway (darker red) and the nitto rear strut bar on (lighter red).
Xdrajicalxd I can't wait to see the pics, and your thoughts on the entire setup.
Old Feb 23, 2011 | 11:49 PM
firstkingofbeer's Avatar
i believe almost all the suspension parts are exactly the same. i wonder if the yaris rear brake caliper kit would work on the xd just get different rotors or something?
Old Feb 24, 2011 | 04:18 AM
how's the ground clearance with the rear under strut bar?
Old Feb 24, 2011 | 05:21 AM
Nateson's Avatar
Wait until daylight, and I'll post a pic.
Ok here you go. Measured a little below 6.5" clearance (which won't change if you lower your car)Name:  8ac15545.jpg
And yes it would be cool if the yaris rear brake conversion kit could be adapted. If only someone lived in California could drive to Microimage to test out parts to see what would work.
Old Feb 25, 2011 | 06:26 PM
Default Nitto rear upper strut tower bar for the yaris fits the xd
thanks nateson, i think i'll get that after all. i'll be posting pics/instructions of the rear upper strut bar tomorrow when it's all done. it's a very tedious process.
Old Feb 26, 2011 | 07:32 PM
Default Finally installed the rear upper strut bar for the Toyota Yaris on my Scion xD
installation instruction and pics to follow
Old Feb 26, 2011 | 08:36 PM
Default Installation of the Nitto rear upper strut bar on the Scion xD
unboxed
after removal of plastic covers.
grip bottom bolt with adjustable wrench, use socket wrench to loosen top bolt.
in order to loosen the bottom bolt you must grip the flat part of the strut screw with an adjustable wrench so that it doesn't rotate, otherwise it won't loosen the bottom bolt.
a close up of the removal of the bottom bolt. This whole method can be avoided if you have an air wrench, but i didn't think about it until later.
after removal of both bolts.
strut bar over the strut screw.
put a washer over the screw where the bolts will go on.
you can either use one lock-bolt or two bolts. an air wrench makes instillation a breeze. tighten until it won't get any tighter on the bottom bolt, then the same with the top bolt. then place the socket over both and finish the job. Make sure you have deep sockets for this.
right side.
final proof that the suspension components for the Yaris and the xD are the same.
a Nitto rear upper strut brace for the Toyota Yaris, installed in a Scion xD
Old Feb 26, 2011 | 09:15 PM
Nateson's Avatar
It looks really good man! I also like your center water fall -silver.
Old Mar 1, 2011 | 11:01 PM
thanks. i'm ordering the rear under shock brace on friday. Saturday i'm installing the NST lightened crank pulley. Then installing the rear under strut brace and the Injen cold air intake when they both arrive. The intake is an upgrade to my K&N short ram intake. Then at the end of the month i'm installing my light-weight racing seats, which i will post pics/instillation instructions for.
Old Mar 2, 2011 | 01:46 AM
Nateson's Avatar
I have the injen intake and the lightened crank pulley installed. I like them both, and I have pics of both (even took a pic of the weight difference in the pulleys).
The pulley can be difficult to install. An impact wrench is what I would recommend. I don't know if installation would be different for an automatic though. I tried removing the old pulley with just a wrench, but it would just turn my wheel with it. So I tried different things ( I can't remember what, I've drank since then), but even with someone in the car pressing the brakes while I wrenched on it I couldn't get it to work. What little progress I could turn the nut would be eaten up by the flex in the clutch springs (I assume). So I ended up using an electric impact wrench to knock off the old and secure the new. That little electric impact wrench I got from Walmart has been worth its wait in gold ($30). It's supposed to be torqued to something like 140flbs to 150lbs, but my torque wrench doesn't go that high. I couldn't do it by hand on jack stands anyway. So my thought process was if it (the impact wrench) could knock off the old then it should be able to secure the new. I've been keeping an eye on it, and no problems so far. My car is a manual, I don't know what yours may be.
I've enjoyed my Injen intake so far, but I am curious about the short ram intakes. Supposedly you get better response, but the cold air gives a little more power. I am keen to hear your thoughts between the two. Having the Injen intake I also bought their Hydro Shield. I have since removed the Hydro Shield because I've found that it tends to let moister sit on the filter. I have some pics if you would like. I think the scenario was either it sat a couple of days or it was just a couple days later. Either way, days after it rained I popped the hood to look at something and reached down. I felt that my filter was damp. I removed the filter with Hydro Shield and saw it was a little moldy and damp. After inspection of the filter sans shield it was just on the bottom. Apparently the shield helped retain some moister which accumulated on the bottom of the filter where no direct water would be able to reach. I believe I'm better without it, and hey might save you some money.
Old Mar 7, 2011 | 08:23 AM
drkness's Avatar
If they just let me test out parts for a day/week, whatever. I will totally drive 500 miles over there to do it. i def want to get rid of this stupid rear brake drum!
Old Mar 7, 2011 | 09:35 PM
RICANTC's Avatar
1UP Crew
Great info yo, definitely something to pick up in the future. Did my tien s-techs, strup and axle-back, and tanabe tower brace yesterday. Here's a pic of tower brace.
Attached Thumbnails Nitto lower rear strut bar fits!-xd-tanabe-tower-brace2.jpg
