Nitto lower rear strut bar fits!
Yes you do. There's a jack point on the back to lift the entire rear end. It looks like a 3 or 4 inch wide prong. You'll also need something to leverage the wheel back up to the stock to slip the bolt through. I used a 2x4 and a hammer handle to make a long armed lever to push it into place. If you need more info don't hesitate to ask. I can also get some pics.
Hope this helps
^^^Now this is really vague, so I ended almost jacking it up in the wrong spot.
^^^This is where you're suppose to jack it up at.
Now for the four bolts that attach to the spring seat on each side will just take some time. I put the washer and nut up top on three because it was easier that way, but one I had to reverse because I just couldn't fanagle it like the others.
Oh and thanks Ricantc for posting the pic!
Unlike the TRD bar this bolt must be all the way out to install this bar. Really this part was easy to remove and install!
