idle problem
So it revs up and stays at that rpm then it just turns off?How long does it stay on?Does it ever seem like it does not want to start?Im kinda leaning toward a fuel pump.Any more info?symptoms?
well it revs to like 3 grand on startup and then shuts off and it take a few seconds for it to start everytime i recently changed the plugs it didnt do it before that though so maybe the gap on the plugs is off?
Hummm
.Well most plugs are pre gaped but should be checked.Are you running NGK plugs?And if it revs up to 3k then turns off i dont think its the pump now.Check your wires to while you check your plugs to make sure they are not frayed maybe a bad signal.Im just tossing ideas out if anyone else has something help out.
Well in his other post he had a misfire in #1 so he changed the plugs now has this issue,any one got ideas?or what compression our motors are at to see if #1 has failed on him
Could be a massive vaccum leak. Check PCV hose , Brake booster hose.
If nothing found there , test the fuel lines for leaks , might be sucking air so it could be the pump in the tank, there is a hose that goes on the pump for the regulator and they do crack at weird times.Does it have a full tank? A full tank would cover the air leak in the tank until the level drops.
Actually, I did exactly that when I re-installed a motor. The correct order (from belt side to transmission isde) for the plugs that connects to the coil packs is black, grey, black, grey. I had them installed grey, black, grey, black and fouled out two of the four plugs.
Quickly realized the issue and swapped back, no issues after new plugs.
BigJohn, if you need extra coil packs let me know, I've got two spare sets. I forgot to reconnect my PCV line @ PTuning on a dyno run, took them a while to find it and they weren't happy about it. Probably wasted 2 or 3 pulls because of it.
RY_TC07
Jul 18, 2017 05:18 PM
cid_mcdp
Jan 5, 2015 02:45 PM
