Scion xD Drivetrain & Power Engine and transmission discussions...
Starting Problems...
Old Mar 24, 2011 | 12:58 AM
DerekSmith's Avatar
Default Starting Problems...
I went to start my 2008 xD the other day and it really did not want to start. When I turned the key, the engine just kept turning but would not start. Being an ex mechanic of carburetor vehicles, I gave it some gas while trying to start, and it finally turned over.
When it finally started a puff of white smoke came out of the exhaust and I could smell gas pretty strong. Any theories as to what may have caused this would be greatly appreciated.
Old Mar 24, 2011 | 09:56 AM
Nateson's Avatar
White smoke is usually gas. You need three things for combustion: air-gas-fire. Check your spark plugs, and see what they tell you.
http://www.superchargersonline.com/content.asp?ID=11
Or
http://www.superstreetonline.com/tec...ugs/index.html
Old Apr 16, 2011 | 09:41 PM
L337R3dN3k's Avatar
Any news on this? Has it happened again? That sounds to me like you flooded the engine -- the most common way is to start the car, move it a very short distance (back it out of the garage, or move it down the driveway), then shut it off, then repeat to move the car back into the garage and let your car sit overnight. In the morning ... yeah, it might not want to start.
If it's not a recurring problem I'd bet there's nothing wrong.
Old May 2, 2011 | 06:19 AM
Luisfc1972's Avatar
update?
Old Oct 7, 2012 | 02:20 PM
Superhatch's Avatar
I've solved it!
Well, not me, my mechanic. They diagnosed it as a failing fuel pump. We explained the issue as noted above, but also noted that it was harder to start in the winter, or if the car sat for longer than a day. They packed the pump area with ice and recreated the problem. Replaced fuel pump 1 month ago, have had 0 start-up issues since!
Jordly221
Feb 13, 2019 05:29 PM
NinjaPilot
Feb 29, 2016 02:58 AM
mw1957
Mar 16, 2015 06:00 PM
cid_mcdp
Jan 5, 2015 02:45 PM
BV19869
Dec 11, 2014 06:05 PM
