Brake bleeding with ABS
Old Apr 15, 2011 | 03:58 PM
Glowbox's Avatar
Default Brake bleeding with ABS
So in a few days im gonna be removing the end of one rear brake line to change the drum brake backing plate for only about 30 seconds and i figure i better bleed the system in case any air got in.
I know how to bleed the system with the pump and hold method with a friend where they push the pedal 3 times, keep it pushed down, open bleeder 1/4 turn for 2 seconds, tighten bleeder, release pedal and repeat until all air bubbles are out while making sure reservoir never goes dry.
My question is do i have to do anything different since the scion xb 2006 has ABS? Ive heard some cars with ABS have to use a scan tool to activate ABS actuators to remove air bubbles, but Ive also heard they are sealed and disconnecting a brake line for a moment wont let air into at least the ABS portion
Can i just do the traditional bleeding and be safe?
THANKS!
Old Apr 15, 2011 | 06:31 PM
Reactor's Avatar
http://scionlife.org/Scion_Docs/2004...d/bleeding.pdf
gqdabien
Oct 8, 2015 05:36 PM
Klashan
Sep 24, 2015 12:39 PM
DannyBoy65
Sep 21, 2015 06:23 PM
axB
Sep 18, 2015 06:11 AM
Subaru86
Scion FR-S Aero & Exterior
Sep 14, 2015 12:39 PM
