how do u drill out a rivet
Old Mar 18, 2005 | 05:48 PM
goldenarches69's Avatar
Default how do u drill out a rivet
hi, i was trying to put in new speakers in my xb in the front doors and theres stupid rivets. how do u drill them out. is there an alternative that i could do thanks
Old Mar 18, 2005 | 05:54 PM
SCI_TC_GUY's Avatar
the only alternative is to cut the speaker from the mount....this will trash your stock speakers but you'll be able to use the brackets to fit your new speakers...
to drill them out, get a bit the size of the small indent in the middle of the rivet, and just go straight through it.......it should just fall apart when you drill all the way through.......after removing the old speaker and bracket, you can easily make a new bracket/spacer out of MDF, a drill, and a jigsaw......
Old Mar 18, 2005 | 06:03 PM
how do u do that? how does the speaker mount up
Old Mar 18, 2005 | 06:19 PM
naztyTC's Avatar
thats how i mounted my id's just rip out old speaker and place new one in works fine i had to make a braket to fit the rears tho
just use self tapers to mount speaker in the old mount
Old Mar 18, 2005 | 06:26 PM
SCI_TC_GUY's Avatar
the only reason i didn't take this approach is that I didn't like the rigidity of the stock mounting brackets.....so I went with the MDF....
Old Mar 18, 2005 | 06:33 PM
naztyTC's Avatar
yah i should have used the mdf for the fronts i did use mdf in the rear tho .. i might still redo the fronts. i want to get some focals its a never endin battl
Old Mar 18, 2005 | 06:35 PM
sorry im stupid but whats a self taper?
Old Mar 18, 2005 | 06:47 PM
sciondude410's Avatar
A self tapping screw is a screw that drills its own hole for you. These are mostly used in metal and plastic cause of the hardness of the surface.
Old Mar 18, 2005 | 06:51 PM
SCI_TC_GUY's Avatar
it's a screw....go to a local hardware store or home depot and ask them for self tapping screws...they'll know
Old Mar 18, 2005 | 07:10 PM
kacosta's Avatar
you drill out the center of the rivet with a 5mm drill bit then cut the old speaker surround and cut the basket out leaveing the center to mount your speaker to the rears have bolts so you know how to remove those do the same mutalation job to it then you can use those as a base i installed infinity 500si and 600si (deep mount fronts) they have rotateable tweeters and they sound great and are inexpensive
Old Mar 18, 2005 | 08:08 PM
SCI_TC_GUY's Avatar
.....i think the point of cutting the speaker from the brackes is to aviod drilling out the rivets.......
Old Mar 18, 2005 | 08:19 PM
kacosta's Avatar
ether way... but someone may want to remove and not know how. i also used the connectors on the basket houseing so the factory connectors could stay.
Old Mar 18, 2005 | 08:24 PM
is there a way to be able to use the factory speaker harness with new aftermarket speakers?
Old Mar 18, 2005 | 08:29 PM
SCI_TC_GUY's Avatar
that's what this guy just said.....he cut the wires from the basket instead of cutting and splicing the harness off...
Old Mar 18, 2005 | 08:39 PM
naztyTC's Avatar
thats fine if your using low power but i wouldnt recomend anything over 30-40 watts on that thin factory stuff
Old Mar 18, 2005 | 09:54 PM
little_black_box's Avatar
After you drill out the rivits you can get an adapter to install your new speakers. I got mine from crutchfield.
http://www.crutchfield.com/
StxArOne
Scion xA Aero & Exterior
Aug 29, 2015 03:29 PM
stayintrucha
Scion tC 2G Aero & Exterior
Aug 20, 2015 06:05 PM
10spokess
Aug 16, 2015 02:50 AM
surfcitylocal
Aug 4, 2015 06:52 PM
erikcooper
Aug 9, 2004 01:54 PM
