Clutch Engagement Adjustment
Old 07-16-2011, 03:35 AM
Vindiesel075's Avatar
Default Clutch Engagement Adjustment
Is there anyway to adjust the engagement? I jsut installed a 6 puck Comp Clutch and it Pulls out right off the floor and doesnt disengage until I push it completly to the floor. Is there a way to adjust the pedal for a better pull that is closer to the middle of the clutch pedal travel?
Vindiesel075 is offline
Old 07-16-2011, 02:46 PM
MN Scions
Jdub86's Avatar
I have driven other cars with heavy clutches and all of them have been like that. To my knowledge I dont think there is a way to adjust it.
Jdub86 is offline
Old 07-16-2011, 03:04 PM
05rs1's Avatar
I'm having the same problem. Ive change the master, replaced the rubber line to a hard line, bled the ____ out of it, adjusted the pedal all the way up top, added a longer rod on the slave, I'm all out of ideas. It sucks because I can't go through the gears quickly, it grinds the gears. Please some one HELP!!!!!
05rs1 is offline
Old 07-16-2011, 03:05 PM
05rs1's Avatar
I have the ACT 6puck with their most aggressive pressure plate.....
05rs1 is offline
Old 07-16-2011, 04:31 PM
SandMPerformance's Avatar
as far as I know, there is no adjustment for the clutch pedal.
SandMPerformance is offline
Old 07-19-2011, 02:01 AM
You say u did adjust the pedal so there is some adjustment on the floor or did you have to modify anything?
Old 07-19-2011, 03:05 AM
05rs1's Avatar
theres a adjustment u can make on the back of the pedal...just look behind it....
05rs1 is offline
05rs1's Avatar
it adjusts the height of the pedal...
05rs1 is offline
Old 07-19-2011, 10:31 PM
malrki42's Avatar
i had the same problem... i cut the rod in half behind the clutch got a seprate rod and a longer nut and tied the 2 together and now my clutch disengages about halfway or higher
malrki42 is offline
Old 11-27-2020, 03:17 AM
interstone696's Avatar
Did you ever actually get a real answer or solve this issue? I just picked up a 2007 Psion TC, it just had its clutch replaced with a stage to clutch. What I notice is it engages about and 2 inches from the floor. When I am completely stopped, I have to jam it all the way into the floor as hard as I can just a shifted into first gear without it grinding. And even then sometimes are here are some grinding. It seems like it’s not fully engaging but I’m not having any sleeping when I’m driving. Any help would be greatly appreciated
interstone696 is offline
Old 11-27-2020, 06:51 AM
JakeAut0's Avatar
It seems like you mean that your clutch is not fully disengaging, instead of not fully engaging, as you mentioned. How a clutch works is that you push the clutch in to disengage the transmission from the engine, shift to the desired gear, then let the clutch out to re-engage the engine and transmission. So, this is the reason for your gears grinding as the clutch is not fully-disengaging.
Unlike older clutch systems that use a cable to adjust the clutch, ours uses a hydraulic system integrated with the brake reservoir. So, for higher stage clutches, the higher clamping force of the pressure plates causes the low disengagement and re-engagement of the clutch as more pressure is now required to compress the pressure plate fingers completely down. Sometimes this can be too much pressure for the hydraulic system, and it results in the low disengagement and re-engagement of the clutch, as I said before.
The clutch disengagement/engagement height could possibly get better once the clutch is broken in, assuming your clutch is not broken in yet. I would have someone press the clutch while you watch the slave rod move (look for weird/bad movement) or record it with a device if you can't get someone to press the clutch. You could also inspect the slave cylinder as well as the brake reservoir.
JakeAut0 is offline
WRX1316_TcVicent
07-22-2021 06:06 PM
yhwhdesign
06-11-2021 03:34 PM
elwaylite
08-09-2015 09:21 PM
Subaru86
07-31-2015 04:33 AM
Mjdavis1994
07-18-2015 04:29 AM
Quick Reply: Clutch Engagement Adjustment
