Timing chain stuck?
Old Nov 28, 2020 | 10:04 PM
Dannyhight's Avatar
Default Timing chain stuck?
Ok this is my first time changing the timing cover on the Scion tC engine. And someone said I had to rotate the timing chain before replacing the cover.
When I did that the timing chain jumped, and I was like I don’t know if that’s supposed to be happening and I crank it two more times and now it’s stuck and I don’t want to do anything now.
What’s wrong with it? It’s loose on one side and tight on the other side. Did it jump teeth or something? How do I fix this. It was rotating fine before this.
Old Nov 29, 2020 | 03:09 AM
JakeAut0's Avatar
When you say the timing chain jumped when you cranked the engine, do you mean the chain jumped teeth? You could try cranking it counter-clockwise (Very Carefully) and see if it frees it.
Old Nov 30, 2020 | 11:35 AM
Chunjee's Avatar
Normally rotating a few times manually is recommended to check timing stays lined up. Not super familiar with this one however.
BlueToaster
15
Feb 3, 2022 04:42 AM
6885BLM8435
Aug 19, 2015 03:08 PM
Hacked_Alias
Nov 22, 2014 05:39 AM
tneely
31
Jan 24, 2011 05:55 AM
swan03tc
Nov 7, 2010 11:36 PM
