Those who rock a front end mask
Old Mar 22, 2005 | 04:01 PM
mattxb's Avatar
Default Those who rock a front end mask
I purchased this item a little while ago to proctect the hood from the already massive amount of paint chips and dings I have. I washed the box the other day and installed. Easy enough..... However, it does not seem to want to sit still. When I am driving on the highway if flops all around and makes a funny noise between 58mph and 65mph. I followed the instructions to a T, so I was wondering if this is the norm with these things or what? Any insight would be helpful. Thanks.
Matt
Old Mar 22, 2005 | 04:13 PM
-Keith-'s Avatar
I never had a problem with mine what brand did you get?
Old Mar 22, 2005 | 04:19 PM
mattxb's Avatar
It is the front end mask that scion offers, just for the front hood portion.
do you have the same one or another brand?
Old Mar 22, 2005 | 04:54 PM
-Keith-'s Avatar
I got mine used but I think its the same one... has the triangles at the top of it...? slips over the front clips in the rear or somin
Old Mar 22, 2005 | 05:32 PM
HollyDo's Avatar
I have the dealership one that says xB on the left side - mine doesn't have any problems and it is really tight. Are you sure you attached it to the farthest hole on the hood? You have to really stretch it to get it there................
Old Mar 22, 2005 | 06:24 PM
mattxb's Avatar
Yea, thats the one. I will double check where I attached the end clips. Good tip, thanks.
Old Mar 22, 2005 | 06:30 PM
xBino's Avatar
Make sure that front end mask is clean and that you clean it often! If it's flopping around in the wind, it could scratch up your paint real quick.
Old Mar 22, 2005 | 06:43 PM
mattxb's Avatar
no doubt! I thought of that. I knew keeping this thing on my car would entail some maintaining, which was initially a turn off for me, then as winter started hitting hard and the front end of my hood started to look like swiss cheese I figured it would be worth the maintenance!!!!
Old Mar 22, 2005 | 08:54 PM
sexyscionlover's Avatar
yea ive got the same one you do and dont have any problems
yea, just make sure its gets stretched in the farthest holes and you tuck it under on the ends, and you're good
Old Mar 23, 2005 | 04:23 AM
UnFocused's Avatar
this is why I have a clear bra!
I bought a 12" by 8 foot section of 3M clearbra off eBay, and did the install myself- cost me $40 total!
Old Mar 23, 2005 | 11:17 PM
xBino's Avatar
Do you need a special ahesive to apply clearbra? Or is it just applied using denatured alcohol, water, and a squeegee?
$40 is a great deal btw
Old Mar 23, 2005 | 11:30 PM
peterbilt's Avatar
yep, I had that same one - the "front mask" from the dealer. $44. CF look, w/ an xB in the corner. it went on very tight, but still flopped around. I took it off after two days 'cause it was making a nice line in the clear coat.
I'm seriously considering the Colgan - like Hawaiianbuilt has.
Old Mar 24, 2005 | 03:06 AM
UnFocused's Avatar
the 3M clear bra has adhesive on the back of it...you just clean the section with rubbing alchohol and spray down the surcface with a solution of 60% water, 40%alchohol and one drop of baby soap. then you peel the backing off and apply, then squeege out the solution.
i made a template out ouf butcher paper first.....
Old Mar 27, 2005 | 05:34 AM
bB2NER's Avatar
Music City Scions
I'm trying to order my Colgan full bra but am waiting for some answers to questions I had. Wanted to know if I can get it without the foglight holes. We'll see....
heiko592
Oct 14, 2020 02:48 PM
Scion0814
Scion tC 1G Aero & Exterior
Feb 15, 2015 10:02 PM
Ramroids55
Jan 16, 2015 02:42 PM
toyotaisme
13
Nov 14, 2003 01:37 PM
sensez
13
Nov 8, 2003 12:10 AM
