Projector + HIDs? Help Please
Old Oct 6, 2012 | 09:16 PM
miltxd's Avatar
Default Projector + HIDs? Help Please
Hey guys, I'm new to the forum, and I haven't really posted up anything.
But i really need your help.
So I've recently purchased and installed projectors for my 05 Scion xB and I was wondering how i can put HIDs for my low beam. Since it was a plug n play projector, im running h3 low beams, with h1 high beams. If it was just the normal H4's I wouldnt have any problems. I tried contacting the seller, but all he says is take it to a professional.
Here is the link of the eBay projectors: http://www.ebay.com/itm/140765199185...84.m1497.l2649
any help would be needed appreciated thank you! :D
Old Oct 7, 2012 | 04:39 AM
jeddyxD's Avatar
just get them H1 bulbs for the H1 projectors since they're already harnessed into H4's there shouldn't be any problem!!!!!!!! XDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDD
Old Oct 7, 2012 | 05:38 AM
miltxd's Avatar
thanks, but im not sure if i'll lose my hi beams
Old Oct 9, 2012 | 06:45 PM
JIMXB's Avatar
His High beam is a H1 on the aftermarket projectors
Question is how to hook up his H3 low beams to HID on a 2005 xB.
If you wish to now to change a H3 regular low beam to HID, you would need to purchase a H3 HID to fit in that hole. Now depending on the aftermarket projector purchase you may or may not need to retrofit for HID use.
Example with "ANZO USA" eagle eye projectors, I had to remove + modify/cut a hole in the rear housing of the low beam projector to insert the HID low beam bulb wire + now the bulb fits in the projector low beam locking socket + works perfect. The only problem is when I need to change the bulb, I have take the projector out to remove the rear low beam housing.
BE sure when you make your HID purchase, that you advise the vendor of your Scion Light bulb wire set up to ensure you received the proper size HID bulb and wire harness for your projectors.
PS You will not lose your high beam, since they are a separate wire from the low beam.
Good Luck
Old Oct 10, 2012 | 01:37 AM
egobuster1's Avatar
i dont see what the issue is here if your low beam is a H3 bulb then order H3 HIDS as i just ordered a set of those for my fogs which take a H3 bulb from ddmtuning.com
Old Oct 11, 2012 | 05:12 AM
miltxd's Avatar
JeddyxD, JimxB and egobuster1
thank you for your help! I'll be following you guy's suggestions once i get my h3 HID's
one more thing though, it wont melt the housing right? Since HID's are lower in wattage?
Old Oct 11, 2012 | 01:26 PM
egobuster1's Avatar
35 watt HIDs arent strong enough to melt the housing but 55Watt theres a possibility but im about to put 55 watts in mine and try them out
Old Oct 11, 2012 | 03:29 PM
miltxd's Avatar
Thanks, can't wait to buy a kit!
Old Oct 12, 2012 | 05:17 AM
miltxd's Avatar
Also I was wondering if there's a tutorial on removing the cut off shield from the driver side projectors? Cause its not as bright as the passenger one
Old Oct 12, 2012 | 01:31 PM
JIMXB's Avatar
If some for reason you need to get inside the sealed headlight. this is the suggested formula: preheat your home oven to 270 degrees + bake for 7 minutes and they'll open up with a little bit of prying.
PS Also, normally when you purchase after market headlight projectors, before you install it is recommended to additional seal your headlight edges with a clear silcone to prevent condensation/fogging of the inside lenses. This is known to happen with aftermarket projectors on certain weather/temperature conditions overnight + can sometimes take all day to fully dissipate. Then if lucky, even with the headlights on to try to evaporate the moisture.
Good Luck.......
Old Oct 13, 2012 | 03:31 AM
miltxd's Avatar
Thank you!, just bought my HID H3 kits, I might install them later this week or during the weekend.
Old Oct 19, 2012 | 02:59 PM
miltxd's Avatar
So I tried installing my hid. I lost my hi beams. Any ideas how to fix em?
Old Oct 19, 2012 | 05:26 PM
JIMXB's Avatar
Your projector headlights are 2 separate lights right? Don't know how you did it, the low + the high are separate connections + bulbs.
If you had install the HID correctly. When you put your lights on normally the low HID3 beam side will go on. To put your regular high beam on, you just do as normal and move/flick your steering wheel column headlight control stick.
Also if the lights dont turn on, the xB may have a reverse polarity issue. I think I had to do this: can be checked by reversing the HID connector on the input side of the ballast + then they should work. It can also be tested by connecting the bulbs and ballasts and using the adaptor cables on the bulb to get power directly from the battery.
Where did you buy your kit from?????
Old Oct 20, 2012 | 04:00 AM
egobuster1's Avatar
a lot of the toyota and scions are known for reverse polarity issues on HIDs but i heard a story about someone else having this issue and i dont rememeber what they ended up doing to fix it
Old Oct 20, 2012 | 05:11 AM
miltxd's Avatar
It was separate. But there's only one plug n play harness and the high beams are connected there as well.
When I unplugged the original harness I replaced it with the hid harness red wire on the right black on the top.
Left one had nothing.
After that, I did the same to the other.
No high beams when I tried turning them on.
The blue "high beam" sign shows though.
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
hondajt
Dec 14, 2015 12:54 PM
Guilles_Tc
Scion tC 2G Aero & Exterior
Oct 15, 2015 03:09 AM
alias55
Scion tC 1G ICE & Interior
Sep 22, 2015 07:50 PM
Renuco612
Sep 16, 2015 09:01 AM
