Component set impedance
Old Apr 8, 2005 | 07:05 PM
SCI_TC_GUY's Avatar
Default Component set impedance
Hey guys.....i have JL VR 650-CSi components hooked up to a fosgate 301s amplifier in my tC.....my question is: Is there any way to drop the impedance of both the left and right channels to 2 ohm?? Possibly via some type of small capacitors or resistors or something plugged in-line from the amp to the crossovers??? any help would be appreciated....
Old Apr 8, 2005 | 07:35 PM
SCI_TC_GUY's Avatar
anyone???
Old Apr 8, 2005 | 07:41 PM
mandos's Avatar
I've looked briefly for something like that and haven't found anything.
Any reason why? Just want more power out of the amp?
what does the 301s put out at 4 ohm stereo?
Old Apr 8, 2005 | 07:46 PM
SCI_TC_GUY's Avatar
4 ohm stereo it's only 75watts per channel...which is plenty for the VR's.....i was just wanting to experiment mainly......
I know there are some people who build their own x-overs and stuff to set exact impedance and slopes....but I'm not farmiliar with any of these technicalities.....
Old Apr 8, 2005 | 07:48 PM
LavaBox_v1's Avatar
Can the speakers go down to 2 ohm? Is the amp 2 ohm stable? If the speakers can't go down to 2 ohm or the amp isn't stable at 2 ohm I wouldn't reccomend doing this ... The only way really to safely break a speaker down to 2 ohm is by have dual voice coils ... If you only have 1 4 ohm Voice Coil you won't be able to go down to 2 ohm ... Most of you components are 4 ohm ... Why do you want to go down to 2 ohm?
Old Apr 8, 2005 | 08:50 PM
toastbox's Avatar
Not true at all. If you were to wire another set of speakers in parallel to that amp, at the same frequency, you would have a 2 ohm load. But I think what you meant was, the only way to drop the load on a single set of speakers, would be with dual voice coils.
For the orignal poster, here are some good links:
http://www.lalena.com/audio/faq/wiring/
http://www.carstereo.com/rayfes/ohms.cfm
Old Apr 9, 2005 | 02:48 PM
SCI_TC_GUY's Avatar
well......the only solution I've figured out wouuld be to hook a 4 ohm resistor inline with the components......i was mainly asking the question out of curiosity......doubt I'll actually try it......
Old Apr 9, 2005 | 05:16 PM
apuleus's Avatar
Connecting a resistor inline would be "in series". So a 4 ohm resistor would make the load 8 ohms if your speaker is 4 ohms. I don't think there is a way for you to add in a resistor decrease ohms.
Old Apr 9, 2005 | 05:35 PM
bbcrud's Avatar
Scionetics
Wire it in parallel. Cuts resistance in half. But, just the same, why?
Buy better equipment.
Old Apr 9, 2005 | 06:26 PM
apuleus's Avatar
How would you wire one resistor in parallel to a speaker without shorting the circuit?
Old Apr 9, 2005 | 07:50 PM
WarrenSteve's Avatar
all a speaker is, is a resister basically. it wouldnt short anything. like wiring two speakers in parallell. same thing
Old Apr 9, 2005 | 07:52 PM
simplespirit's Avatar
Adding a 4 ohm resistor in parallel would drop the load at the amp to 2 ohms but your components would only get half the power that the amp puts out since the resistor would take half. That means if your amp doubles power output into 2 ohms you would net nothing but a dirtier signal. You'd be wasting your time essentially.
If you want 2 ohm speakers just buy some, Image Dynamics makes their chameleons in a 2 ohm model.
hampton1100
May 28, 2015 07:32 AM
B_Real45
Feb 23, 2015 07:33 PM
corbmonster
Jan 24, 2015 06:13 PM
BManAmericae
Jan 18, 2015 12:17 PM
ScionVan
11
Dec 2, 2003 09:37 PM
