Scion tC 2G ICE & Interior In-car entertainment and electronics...
LED HELP
Old May 21, 2013 | 04:48 AM
hunterovarmy's Avatar
Default LED HELP
alright, I did look through the forum and couldn't really find exactly the answer i'm looking for. so i'm starting a new thread.
I really would like some serious LED work throughout my tc, but i dont know too much about wiring. So I have a blue LED switch in the empty spot next to the fog light switch which is 20A. I would like to go the Fuse method rather than the cig lighter way.
so here is my question...
Should I do the whole "add-a-fuse" thing? if I go that route, do I need to use a spot that is already in use or can I utilize and empty unused spot?
Now if I can use an empty slot, how much power can I pull from that spot? also I'm going to assume that since the switch i purchased is 20A that it would be a good idea to use a 20A fuse correct?
I really don't want to take power from anything such as headlights or cig lighter. I dont want to mess with that stuff. I want all of my LEDs to be dedicated to that switch..
Ideas, advice and recommendations would be helpful.
Old May 23, 2013 | 04:08 PM
TurtleTurtle_12's Avatar
I used an add-a-fuse on an empty constant fuse slot and have 2-48cm, 2-38in, and 2-72in strips (roughly 475 leds total) hooked to it. I'm using a rocker switch rated for up to 15 amps and used a 5 amp fuse in the add-a-fuse. I haven't had any problems out of it, and it's been wired this way for well over six months.
I'm not sure how power can pulled from the empty fuse slot, but I know I will probably never reach its max load.
hondajt
Dec 14, 2015 12:54 PM
jdmautoimports
Regional - Canada
Sep 24, 2015 04:00 AM
Subaru86
Sep 14, 2015 12:43 PM
SJMiller
Sep 12, 2015 06:33 PM
