Need some input on peoples who know superchargers
Old Jun 29, 2005 | 06:52 AM
xmetalx's Avatar
Default Need some input on peoples who know superchargers
ok so i was reading on scionclub.com or something under the internals thread and some guy got custom rods and pistons to build up the bottom end for a turbo. I remember reading that anything over 6-7 PSI and you risk a high chance of bending rods and stuff. So my question is with custom rods and pistons could i run higher boost and hit maybe 160 whp and still keep reliability of my car, this guy spent 1200 or so on rods and pistons to do a future turbo setup. I know for sure now that i want to go F/I within the next 1 1/2-2 years so this would be the first step? any info advice help etc? im not looking to swap a 1zz either, i want to keep the stock 1.5
Old Jul 1, 2005 | 02:54 AM
Tamago's Avatar
yes. building the engine = more boost capability. but less driveability OFF boost.. (lower compression pistons means your car is gonna be a dog without some boost)
Old Jul 1, 2005 | 05:52 AM
TheScionicMan's Avatar
The parts will be stronger, but are they going to be strong enough to over come the problem EL Prototypes talks about:
These engines have the crankshaft offset 12mm to the thrust side of the cylinder bore centerline. This reduces the side force generated at maximum compression, for reduced friction and improved fuel economy. Toyota calculates the offset crankshaft configuration reduces fuel consumption by between one and three percent. Unfortunately, this throws the angle of the rod way out on its upward travel causing the rod to just give up under boost and snap. If there is any detonation or pre-ignition this breakage will occur at an accelerated rate.
http://elprototypes.com/1nz%20turbo.htm
These engines were designed for economy over high-performance. IMO, if you're going to spend all that money to build up and then boost an engine, it should be one that is better suited for it. ELP's page does have this listed, but was last updated a few months ago...
4e-fte engine install kit for xB IN DEVELOPMENT NOW !
Old Jul 5, 2005 | 06:32 AM
Xbilly's Avatar
doesnt that engine only have like 135 hp anyway? you can get there with an s/c
Old Jul 5, 2005 | 03:49 PM
dgHotLava's Avatar
but if you start with 135ish
then boost it you will end up with 180+
Old Jul 5, 2005 | 09:10 PM
Xbilly's Avatar
I thought 4e-fte came turbo'd already, i must have been mistaken.
Old Jul 5, 2005 | 10:44 PM
dgHotLava's Avatar
i think it does, but it has soooooo much more potential...
Old Jul 6, 2005 | 06:50 AM
jwa276's Avatar
yeah the engine in stock form can take quite a whopping amount of boost..
just sucks to live in cali and have to worry about smog.. w00t for columbus OH and no smog! :D
-jon
ColonelSanders85
Dec 9, 2020 09:44 AM
fur_pig
Mar 20, 2020 04:28 PM
rain7905643
12
Jun 13, 2018 05:34 AM
GoodVibes
Mar 3, 2015 09:47 PM
RichBinAZ
Dec 21, 2014 12:05 PM
