AEM Cold Air Intake maintenace questioin
Old Sep 22, 2005 | 05:05 PM
beigemonito's Avatar
Default AEM Cold Air Intake maintenace questioin
Does Anyone know how to remove the AEM Cold Air Intake Filter for recharging on an XA? I want to do mine but since id didn't put it in, don't know how to service it.
Any Help would be greatly appreciated, I read the Tech post about the K&N filter but what about the AEM one, it is different.
-Daniel
Old Sep 24, 2005 | 08:19 PM
grizzly_choppers's Avatar
You need to raise the front end of the vehicle. Use either a jack AND jackstands or ramps.
Get under the left front corner and unbolt the splash shield there (should only need a 10mm wrench). Use a screwdriver or socket (8mm maybe?) to loosen up the clamp holding the filter on. Wiggle it off of the end of the CAI and remove through the bottom of the car. Clean it, charge it (don't go too nuts on that oil) and reinstall it from the bottom. Don't run your car with that filter off though!
Good luck!
-Alex
Old Sep 27, 2005 | 07:23 AM
Default Thanks so much man!
Thank you so much! So it's right under the bumper or from the wheel well?
-Daniel
AbsoluteRedtC
Dec 31, 2014 06:18 PM
cabphil62
May 18, 2012 05:53 PM
kagero79
10
Dec 24, 2003 04:23 AM
2002cbr600f4i
Dec 6, 2003 02:01 AM
Cheshire_Cat
Nov 30, 2003 08:52 AM
