AEM Cold Air Intake maintenace questioin
Does Anyone know how to remove the AEM Cold Air Intake Filter for recharging on an XA? I want to do mine but since id didn't put it in, don't know how to service it.
Any Help would be greatly appreciated, I read the Tech post about the K&N filter but what about the AEM one, it is different.
-Daniel
-Daniel
You need to raise the front end of the vehicle. Use either a jack AND jackstands or ramps.
Get under the left front corner and unbolt the splash shield there (should only need a 10mm wrench). Use a screwdriver or socket (8mm maybe?) to loosen up the clamp holding the filter on. Wiggle it off of the end of the CAI and remove through the bottom of the car. Clean it, charge it (don't go too nuts on that oil) and reinstall it from the bottom. Don't run your car with that filter off though!
Good luck!
-Alex
Good luck!
-Alex
2002cbr600f4i
Dec 6, 2003 02:01 AM
