Regional - Deep South AL, AR, LA, MS
Turbo's and Tranz Question!
Old Jan 5, 2006 | 12:25 PM
scion_tiger's Avatar
Default Turbo's and Tranz Question!
I am thinking of putting a turbo in my xB, but I need to know before I do it if I need a new transmission! I know that I need bigger fuel injectors, but I have had mixed feedback on this issue. Some say that I can use my stock transmission and others say that I must upgrade it! At this point I don’t want to spend money on the turbo system till I know if I have to spend even more money on another transmission! PLEASE HELP!
*******LOCKED*********
Please don't post the same thing in multiple forums.
Old Feb 23, 2006 | 01:48 AM
superfreestyle's Avatar
DeepSouth Scions
the stock trans is fine... you must upgrade your clutch and pressure plate... there is a 6-speed trans that is almost bolt-on, requires a little modification to the bell housing and a little finess but toyota makes one to fit.
you will need the 1.8Litre toyota MRS injectors they are 260cc, the stock ones are 200cc, you should look into the ZPI F/I cylinder head and pistons also. If you plan on putting a lot of boost on it you may want to find some bigger injectors
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
