ANY ONE HAVE AUTO START IN STANDARD TRANNY
Old Jan 30, 2006 | 06:32 AM
chenzstc05's Avatar
Scion Tuners
Default ANY ONE HAVE AUTO START IN STANDARD TRANNY
Hey everyone does any one have any tech tip so if your alarm know your in not in gear. I heard of a home alarm magnet. But looking for some more ideas. Looking for feed back thanks
Old Jan 30, 2006 | 06:52 AM
crayonBOX's Avatar
i believe there is a write up in the tech section
if not - what you'll need to do is set up a clutch bypass so that your remote start will start the car, as if the clutch is in.
on the other hand. you'll have to leave your car in neutral, so you never start it in gear and *WHAM!* hit the cars around you (many ppl have stories on this one)
this was posted before btw.
by the look of your q - you're trying to prevent the car from starting if it is in gear and you forget?
you could use a Reed switch (which is the home alarm magnet you mentioned) and place two of them around the shift mechanism, or in place where you leave your car in gear (usually 1st).
Old Jan 30, 2006 | 11:56 AM
SmartAss's Avatar
Theres a few companies tha tmake them for manual vehicles like compustart.
When you park the car and pull up the e-brake the remote start activates and keep the car running. You take the key out as the car keeps running and get out of the car. Once you shut the door the car turns off knowing that the car was running and all the doors were shut it will start up for you. But if you open a door before the car is remote started it wont start for you.
Old Jan 31, 2006 | 06:51 AM
insanelyx's Avatar
the best i've seen installer... are MERCURY SWITCHES on the shifter.. good thing.... no remote start is shifter is in gear.. bad... works only on good flat surfaces.... hills... bad.
Old Feb 1, 2006 | 12:12 AM
chenzstc05's Avatar
Scion Tuners
well Thanks for the help guys But some one said to use a proximory switch I'm going to try That Thanks
Old Feb 1, 2006 | 07:01 AM
insanelyx's Avatar
great... tell us how it works out for u.....
Old Feb 2, 2006 | 05:08 PM
yellot00tr's Avatar
get a compustar or arctic start alarm system. i have it on my tc now and my last one too. works with the manual without needing any extra sensors, things, or whatever. the remote start on the one i have now works 1.25 miles away, and only works if the car is shut down with it in neutral and the e-brake on. if the car isn't in neutral and the e-brake isn't active, then the car won't remote start.
Dmmcclair
Aug 13, 2015 07:14 PM
mw1957
Mar 16, 2015 06:00 PM
toyotaisme
Jan 10, 2015 10:24 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
Risen_Son_Racing
May 6, 2005 02:31 PM
