Dash lit up like a freakin UPDATE BELOW!
Old Feb 28, 2006 | 03:39 PM
cierrecart's Avatar
Default Dash lit up like a freakin UPDATE BELOW!
An appointment has already been made with the dealer for this afternoon, but I wanted to see if anybody here has some insight. Wife went out to the 06 xB this morning and turned it on and she got the following lights:
VSC
Trac Off
Check Engine
I figure they are all related to the VSC system having a problem, and a quick check of the manual confirmed that if there is a problem with the VSC system then the Trac Off light will pop up as well, and I know that the check engine light will come on when there is a problem with any sensor on the vehicle.
Manual says it's okay to drive, but I didn't pay for the warranty and ____ to just let it go or get my hands dirty trying to fix it.
It is pouring rain here in SoCal, so I'm thinking something got wet....but who knows.
Any ideas?
Old Feb 28, 2006 | 03:41 PM
THE_DON's Avatar
Got an intake?
-THE DON
Old Feb 28, 2006 | 03:56 PM
cierrecart's Avatar
Nope...car is completely stock except for some aftermarket wheels (15")
No other problems with the car at all, just over 6k on the clock.
Old Feb 28, 2006 | 04:07 PM
THE_DON's Avatar
Gas cap may not be on tight then....
Other than that, you would have to run the codes.
Good luck, hopefully nothing major.
-THE DON
Old Feb 28, 2006 | 04:15 PM
cierrecart's Avatar
Yeah, I'm aware of the gas cap deal, and I usually make sure it goes past 2 clicks...but who knows....maybe I neglected when I filled it up on sunday.
Oh wells....time to see if the dealer is as cool as they were when I bought the car. I'll keep everybody posted.
Old Feb 28, 2006 | 04:23 PM
atomic's Avatar
disconnect the battery. i had the same problem last week it has some thing to do with the steering wheel.
Old Feb 28, 2006 | 04:25 PM
cierrecart's Avatar
Disconnecting the battery will not fix whatever caused the problem to begin with. All it will do is reset the ecu and the lights will come back on once the car goes through a drive cycle.
Old Feb 28, 2006 | 04:53 PM
MrMcNuggett's Avatar
my polar white did that when i got it.....took it down to the dealer and it had a misfire in the spark plugs they replaced them and it is fine now
Old Feb 28, 2006 | 07:08 PM
evilBOXevil's Avatar
You said you didnt pay for the warranty, but the car only has 6k on it? You don't have to pay for the warranty up to 60k...some people pay for an extended warranty, but this is covered.
Old Feb 28, 2006 | 07:11 PM
cierrecart's Avatar
What I said was that I didn't pay for the warranty so that I would be the one messing around trying to fix it.
Old Feb 28, 2006 | 07:26 PM
Sorry...me no reed so good theez wurds.
Old Feb 28, 2006 | 08:23 PM
IH8ONYU's Avatar
for a quick ECU reset w/o disconecting the battery, you can pull one fuse... see the tech forum... ecu reset w/o discon battery
Old Mar 1, 2006 | 04:53 AM
Ponce3212's Avatar
I have that same problem....don't know what it is though but ina few days it would go away and then come a week later....i figured it was something to do with my brakes cause i do have 57K mi on it.....
Old Mar 1, 2006 | 04:21 PM
YABABY's Avatar
Default DASH LIT UP
VSC
Trac Off
Check Engine
Happened in my RS1.0....took it to my favority DEALER.
Charged my 1/2 hour labor and reset the lights (what someone calls the ECU, I guess...not being technical)...DEALER tech called it the "fume sensor" that's set off by not TIGHTENING THE GAS CAP....rats.
Now I'm sure to give the gas cap an extra twist before driving off from the pump.
YABABY
RS1.0 #377
Annapolis
Old Mar 1, 2006 | 06:29 PM
cierrecart's Avatar
AS I said before.....I know how to reset an ECU, but doing so will not fix whatever problem caused it to come on in the first place. If the problem is still there the lights will come on again as soon as the car goes through a drive cycle.
Car is at the dealer now.....nothing but friendly faces so far, just waiting for a response.
Old Mar 1, 2006 | 06:35 PM
THansenite's Avatar
Default Re: DASH LIT UP
VSC
Trac Off
Check Engine
YABABY
RS1.0 #377
Annapolis
Why did they charge you labor? That fix should be under warrenty.
Old Mar 1, 2006 | 07:17 PM
cierrecart's Avatar
Dealer called and said they need a few more hours. I guess the code came back referring to the emissions system, so they have to let the motor cool completely before they can look further.
Old Mar 8, 2006 | 08:34 PM
cierrecart's Avatar
Whelp...turns out it was a bad gas cap. They replaced it and all is well so far.
Old Mar 8, 2006 | 08:39 PM
ha ha ha . wow. cool that it's resolved
Old Mar 9, 2006 | 03:43 AM
cassidy's Avatar
same thing happens to my car and the dealer doesnt know anything about how to fix the problem "of course they dont" so I guess ill try the gas cap
yupinmytC
22
Jul 27, 2024 07:08 PM
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
prescottn
Oct 8, 2015 05:31 PM
ScionLife Editor
Sep 16, 2015 10:00 PM
alexbarspin
Sep 3, 2015 02:04 AM
