anybody know where to get bB badge that DOES NOT fall off?
Old Apr 17, 2006 | 12:08 AM
danman2_2999's Avatar
Default anybody know where to get bB badge that DOES NOT fall off?
damnit!! i'm about to buy my third badge on ebay! does anybody have any tips on how to keep it on the hood or even if there are some higher end badges instead of the shiny plastic? maybe a metal material or something?
I used some double sided tape which kept it on for a long time, but i noticed today that it was gone.
Old Apr 17, 2006 | 02:16 AM
David_Seale's Avatar
what kind of tape are you using? make sure to get the weather proof 3m double sided tape.
im guessing youre talking about the rear emblem? cuz if yourte putting an emblem on the hood, then i dont know what youre doing. and the fact that the emblem is plastic shouldnt have anything to do with it falling off
Old Apr 17, 2006 | 02:55 AM
pornstarmatt's Avatar
Falling off? Or is someone stealing it?
Old Apr 17, 2006 | 03:02 AM
OldYeller's Avatar
I ran this thread a week ago or so--some new bB badges--you will see two Ebay links....
https://www.scionlife.com/forums/vie...730&highlight=
Old Apr 17, 2006 | 03:23 AM
tanakasan's Avatar
1) All are plastic. The JDM are a much better product, fit and finish.
2) Tape means the rear emblem?
3) Are you sure that someone isn't stealing them?
For the front/grille emblem be sure that the clips are fully seated when you install it. Reach around inside the grille and push them apart until you see and hear them click in-completly.
On the back, there is no theft proof solution. And again, the JDM-with the factory adhesive/orange peel off paper already applied-is the best hope for staying on.
Don't get the repopped cheesy emblems. Not worth the $$.
Old Apr 17, 2006 | 03:49 AM
SquallLHeart's Avatar
i'd go to bBist for the badges... have lots of friends with them with no problems.. i think they're all plastic though.. only metal ones i think i've seen were for the rear.
but honestly it sounds more like someone's stealing them.
Old Apr 17, 2006 | 05:43 PM
soylentgreen's Avatar
That was my first thought too.
Old Apr 17, 2006 | 05:48 PM
TheIcon's Avatar
I agree. Make sure your using the correct kind of double sided tape. If double sided tape can hold your previous badge on then you should have no problem holding your new bB badge.
Old Apr 17, 2006 | 10:27 PM
Unless someone is stealing them...
Old Apr 18, 2006 | 01:34 PM
TheIcon's Avatar
If it was being stolen I would think it would leave some extra residue/tape. Unless the theif takes the time to use some cleaner Def possible though.
Old Apr 18, 2006 | 03:34 PM
SCORPIO77's Avatar
You can go to any parts store and pick up a tube of 3M emblem adhesive for the rear emblem. I used it after my emblem started detaching with the doublesided tape and it's on there for good.
Old Apr 18, 2006 | 07:49 PM
evilBOXevil's Avatar
I used the 'duct tape' thin double sided tape...I dont think I could pull off the emblem now- even if I wanted to.
Sounds like theft to me too. When you clean the area to put the emblem on, are you waxing it first? dont. Clean and wipe it dry...make sure no cleaner residues, but don't wax it first, or your tape will fall off.
Old Apr 22, 2006 | 01:52 AM
thanks for the replies! i dont think its being stolen....one day i was walking to my car and i hit the alarm and the vibration from that made it just fall right off, luckily i was able to see it fall off. I was referring to the GRILL, not hood, sorry for the confusion. Have any of you guys had yours yoinked? i was thinking of superglueing it to the grill, the tape i used was 3M double sided tape...not sure exactly what type if its outdoor or what.
btw....would these emblems: http://cgi.ebay.com/ebaymotors/Jdm-T...53591219QQrdZ1
fit the front grill of our stock xBs?
Old Apr 22, 2006 | 01:53 AM
the tape was put on the back of the badge, around the three little plastic pins that hook to the grill.
anybody develope a steal proof technique on putting these on? I was thinking of drill small holes or something in those pins and having either some kind of wire or zip tie or something to hold it in place....any ideas?
Old Apr 22, 2006 | 06:08 AM
Cravin's Avatar
Here is the real Toyota JDM bB front emblen not a knockoff.
http://www.newscionparts.com/product/?id=1055
Old Apr 22, 2006 | 06:12 AM
tanakasan's Avatar
Shouldn't need tape on the grille emblem.
They just clip into the grille. Again, be sure that they are completely seated...check from the inside of the grille. They snap in pretty good.
I thought about making a small bar that goes between the legs so that it cannot be compressed to remove the emblem. Then I thought that someone would just break my grille if they really wanted the emblem. Not good. Better a lost emblem than a broken grille!
Old Apr 22, 2006 | 05:14 PM
damn I'm not sure if i want to keep buying them! since they keep falling or getting yoinked off.
yupinmytC
22
Jul 27, 2024 07:08 PM
SouthernCaliTC
Sep 15, 2015 01:58 AM
ScionLife Editor
Sep 11, 2015 12:53 PM
Dam262a
Jul 28, 2015 03:55 AM
StxArOne
Jul 13, 2015 06:25 PM
