Pioneer AVIC Z1 Questions
Old May 9, 2006 | 12:39 AM
baysurfer's Avatar
Default Pioneer AVIC Z1 Questions
I'm looking to buy an AVIC Z1 pretty soon, but I have some questions about it:
1. How well does it fit into the tC's double DIN opening? Does it leave any gaps, or do you need a kit to fit it?
2. How does it plug in to the car's wiring? Do you need to buy a special harness for it?
3. Do you need a separate adapter to use the Bluetooth functions?
4. Can I keep the steering wheel audio controls, or will I lose those?
Thanks!
Old May 9, 2006 | 12:44 AM
SquallLHeart's Avatar
1. not sure, might be very very small gaps if anything
2. need wiring harness
3. uhh... not sure
4. no, unless you buy adapter.. then maybe yes.
Old May 9, 2006 | 01:16 AM
REaL's Avatar
1. there will be gaps on the left and right side like most double din units have in the tC. there is a part from toyota that fills those gaps up
2. new wiring harness is required
3. the bluetooth is optional, adapter required(not released yet)
4. will need adapter
hope that helps.
Old May 9, 2006 | 11:33 PM
baysurfer's Avatar
Thanks guys. :D
Do you know the Toyota part that fills the gaps?
How complicated is it to do all the wiring? What kind of adapter would I need to get the steering wheel controls to work?
Old May 10, 2006 | 01:03 AM
REaL's Avatar
Originally Posted by baysurfer
Thanks guys. :D
Heres what you need to fill the gaps. I think it would be better if you just make your own out of abs plastic, looks cleaner imo.
http://www.scosche.com/scosche_carau...ItemID=TA1465B
The install of the unit itself isnt hard all you do is tap into the ecu for the speed sensor and the rest is just like doing any other aftermarket radio, but the steering wheel controls look pretty hard...check out this post it should be similar with the Z1.
https://www.scionlife.com/forums/vie...985&highlight=
crimson10tC
Sep 10, 2015 08:44 PM
O5_TRD_tC
Feb 18, 2015 09:01 PM
LaVa~NyC
Dec 13, 2005 03:12 AM
NYCtC
11
Dec 8, 2005 05:36 AM
tckurt
Sep 18, 2004 04:53 AM
