Allignment Settings
Old Aug 17, 2006 | 01:22 AM
jjjosh41's Avatar
Default Allignment Settings
I just installed my H-Techs a week ago and now I want to get the allignment done. I went to the shop and was told that they wouldnt do it to a car that was lower than stock ride height because the specs wont be the same. He said if I got the new specs for the springs to do the allignment he would do it. Is this a normal response?! And if so...where the hell do I get those specs. The only thing that came with the springs were ride height specs and bump stop specs.
Old Aug 17, 2006 | 02:54 AM
BOXMAN's Avatar
No NO NO leave that shop. You can dial the factory camber back in using Ingalls fast cam bolts! Cheapest way and they work! Pick up a set of Ingalls fast cam bolts and head to a good alignment shop in your area. Fast cams will run about 100 bucks top for all four corners but save you from buying a new set of tires for 300-800 bucks depending on your size of rim and tire brand.
Old Aug 17, 2006 | 05:50 AM
jjjosh41's Avatar
So a good shop should be able to set my car on there and use the stock specs that they have in their computers?
Old Aug 17, 2006 | 01:28 PM
jjjosh41's Avatar
Any help?
Old Aug 17, 2006 | 02:19 PM
BOXMAN's Avatar
^^^ Yes you should always be trying to dial you car back to stock specs.
Old Aug 17, 2006 | 03:08 PM
NoLimitzBuilt's Avatar
Team No Limitz
You dont have to use cam bolts all the time either. My car we got the front within a half degree. The rear had to stay cambered in some cause of how low I have the car. they got mine really really close. I have the same tires for almost 15,000 miles and no issues at all.
Old Aug 17, 2006 | 03:38 PM
BOXMAN's Avatar
As long as you get back to within reason of stock specs you will be better off than just leaving it be.
Old Aug 18, 2006 | 05:40 AM
Chapman's Avatar
I have -1.3 camber for my rears and the shop said it's ok since my tires rub a lil bit. -1.3 isn't too bad is it?
Old Aug 19, 2006 | 04:50 AM
jjjosh41's Avatar
thanks for your help guys. I guess ill be going to a different shop.
Erager09
Sep 26, 2016 03:11 PM
danielv
Aug 26, 2015 07:14 PM
toyosg
Scion tC 2G ICE & Interior
Jun 1, 2015 08:43 PM
Tavito
May 28, 2015 08:42 PM
Tavito
