How do I remove the lower steering column housing?
Old Jul 23, 2004 | 05:34 PM
thinkCooper's Avatar
Default How do I remove the lower steering column housing?
I installed a cruise control earlier this week, but wasn't able to get the controller's retaining nut tight enough on the inside of the steering column lower housing. Can someone tell me if I need to remove the steering wheel to fully remove the housing? If so, could you tell where the screws are?
Cheers!
Old Jul 24, 2004 | 06:36 PM
Answered my own question this morning.
Turns out that removing the lower steering column cover is really easy. There are 3 screws. One is below the steering wheel, and easily accessable with a phillips head screwdriver. The other 2 screws face the driver, on the left and right sides of the cover but are hidden by the back of the steering wheel. These 2 screws are accessable by turning the steering wheel to either side. The wheel has a flattened area that when turned allows access to the screws.
Once the 3 screws are removed, the lower steeering column is easily pried away from the upper cover.
I needed a little time to check out the steering wheel to solve my puzzle. No need to remove the steering wheel! That's it! :mrgreen:
Cheers,
Cooper
Inazuma
20
May 3, 2023 01:58 AM
CombatmedicR56
Nov 12, 2020 01:53 AM
10gxiong
Feb 21, 2015 12:53 PM
FurionAlpha
Scion tC 1G ICE & Interior
Jan 12, 2015 08:25 PM
yanges
19
Dec 30, 2003 02:05 AM
